Capacità scheda graficaOne graphics card per holder
RequisitoRequires seven PCI case slots
Modello cavo riserRiser Cable PCIe 3.0
SupportoPCI area of your Case
Peso netto0.230Kg
Colore/iDark Metallic Grey
LegacyAccessories
NotaThis product is only compatible for devices that support the PCI-E 3.0 specification. If you use this product with a motherboard that supports PCI-E 4.0, please enter into BIOS option and select PCI-E 3.0 before installation.
