CDU Compatta Liquido-Aria Aquagate Max Retro Mini image number 0
Potenza compatta. Raffreddamento scalabile. Massima efficienza.
La CDU Aquagate Max Retro Mini Liquido-Aria combina un design compatto con una potente capacità di raffreddamento. Offre soluzioni di raffreddamento liquido scalabili con massima efficienza energetica per ambienti di elaborazione moderni.
Features and Benefits
Features:
  • 1450 to 2000 W cooling capacity
  • Space-efficient footprint and scalable design
  • Diverse device support
  • P80 pump
  • High-quality fans:
    • 240 Series: 8+1 120 x 120 mm fans
    • 280 Series: 8+1 140 x 140 mm fans
    • 360 Series: 12+1 120 x 120 mm fans
  • Square radiator:
    • 240 Series: 240 mm radiator
    • 280 Series: 280 mm radiator
    • 360 Series: 360 mm radiator
  • Aluminum alloy frame
  • 2.9-inch HMI touch screen display
  • User-friendly interface
  • Customizable settings
Benefits:
  • Each CDU handles up to 1450 to 2000 W, ensuring stable performance for high-demand systems.
  • Compact footprint saves space and boosts flexibility.
  • Scalability through chaining increases cooling capacity. Compatible with a combination of CPUs, GPUs, and other critical heat sources.
  • Liquid-to-air cooling outperforms traditional air solutions and reduces noise and power consumption.
  • Durable construction ensures reliable operation.
Mini CDU, Major Cooling Power
Leveraging the superior efficiency of liquid cooling, the Cooler Master Aquagate Max Retro outperforms traditional air cooling, delivering greater thermal dissipation potential.
Whether managing the heat of high-performance CPUs, GPUs, or other critical heat sources, this mini-CDU is built to handle diverse cooling needs with precision. Unlike traditional air cooling or the costly complexity of full-scale data centers, the innovative Aquagate Max Retro bridges the gap, providing adaptable, advanced liquid cooling.
Aquagate Max Retro Mini CDU Control Panel Interface
