TD300 Mesh image number 0
TD300 Mesh image number 1
TD300 Mesh image number 2
TD300 Mesh image number 3
TD300 Mesh image number 4
TD300 Mesh image number 5
TD300 Mesh image number 6
TD300 Mesh image number 7
TD300 Mesh image number 8
TD300 Mesh image number 9
TD300 Mesh
TD300 Mesh
TD300 Mesh
TD300 Mesh
TD300 Mesh
TD300 Mesh
TD300 Mesh
TD300 Mesh
TD300 Mesh
TD300 Mesh
Eleganza postmoderna
TD300 Mesh
Pannello frontale con contorno 3D in mesh poligonale
Pannello superiore rimovibile
Pannello laterale in vetro temperato
Doppie ventole CF120 ARGB
Hub ARGB/PWM
Gabbia per unità adattabile
Supporto radiatore fino a 280mm
Colore
Acquista ora
Specifiche
  • Numero di modello TD300 Mesh: TD300-KGNN-S00, TD300 Mesh White: TD300-WGNN-S00
  • Colore esterno Black, White
  • Materiali - Corpo Steel, Mesh, Plastic
  • Materiali - Pannello laterale Tempered Glass
  • Dimensioni (L x P x A) 366.5 x 210 x 410mm (Body Size), 433 x 210 x 420.5mm (incl. Protrusions)
  • Volume 38.24L (incl. Protrusions)
  • Supporto schede madri Mini-ITX, Micro-ATX
  • Slot di espansione 4
  • Alloggiamenti da 5,25" N/A
  • Alloggiamenti unità 2.5" / 3.5" (Combo) 2
  • Alloggiamenti per unità da 2.5" 2
  • Pannello I/O 2x USB 3.2 Gen 1 (formerly USB 3.0)
  • Pannello I/O 1x 3.5mm Audio Jack
  • Pannello I/O 1x 3.5mm Mic Jack
  • Pannello I/O 1x ARGB Hub
  • Ventole preinstallate - Superiore N/A
  • Ventole preinstallate - Anteriore 2x 120mm CF120 ARGB Fan
  • Ventole preinstallate - Posteriore N/A
  • Ventole preinstallate - Inferiore N/A
  • Supporto ventole - Superiore 2x 120mm / 2x 140mm
  • Supporto ventole - Frontale 3 x 120mm* / 2 x 140mm (*can only mount behind the front plate)
  • Supporto ventole - Posteriore 1x 120mm
  • Supporto radiatore - Superiore 120 / 140 / 240 / 280mm
  • Supporto radiatore - Anteriore 120 / 140 / 240 / 280mm
  • Spazio massimo - Dissipatore CPU 166mm
  • Spazio disponibile - PSU 325mm (w/o front radiator & drive cage), 140mm (drive cage in backmost position)
  • Spazio disponibile - Scheda grafica 344mm
  • Gestione cavi - Dietro il vassoio della scheda madre 18-22mm
  • Filtri antipolvere Front, Top, Bottom
  • Supporto per alimentatore Bottom Mount, ATX
  • Dimensione Mini Tower
  • Serie MasterBox Series
Download
