MWE Bronze 650 - 80 PLUS Bronze Certified Power Supply image number 0
MWE Bronze 650 - 80 PLUS Bronze Certified Power Supply image number 1
MWE Bronze 650 - 80 PLUS Bronze Certified Power Supply image number 2
MWE Bronze 650 - 80 PLUS Bronze Certified Power Supply image number 3
MWE Bronze 650 - 80 PLUS Bronze Certified Power Supply image number 4
MWE Bronze 650 - 80 PLUS Bronze Certified Power Supply image number 5
MWE Bronze 650 - 80 PLUS Bronze Certified Power Supply image number 6
MWE Bronze 650 - 80 PLUS Bronze Certified Power Supply image number 7
MWE Bronze 650 - 80 PLUS Bronze Certified Power Supply image number 8
MWE Bronze 650 - 80 PLUS Bronze Certified Power Supply image number 9
Alimentatore con certificazione 80 PLUS Bronze
• 80 PLUS Bronze
• Design del circuito DC-DC
• Condensatori di qualità
• Cuscinetto LDB durevole
• Basso consumo energetico in standby
• Cavi intrecciati
Specifiche
  • Frequenza di ingresso 50-60Hz
  • Temperatura di esercizio 0-40°C
  • Tensione di funzionamento 100-240Vac
  • ErP 2013 Lot 6 Yes
  • Connettori MB 20+4 Pin 1
  • Cavo FDD con connettori a 4 pin 1
  • Segnale Power Good 100 - 500 ms
  • Dimensione ventola 120mm
  • Cuscinetto della ventola LDB
  • Categoria 500 to 750W
  • Connettori CPU 12V 4+4 Pin 1
  • Modulare Non Modular
  • Versione ATX ATX 12V V2.31
  • Efficienza 80 Plus Bronze
  • Efficienza 85% @ Typical Load
  • Connettori SATA 8
  • Connettori PCI-e 6+2 pin 750W / 850W: x4 = 2x (600+120mm)​ 1000W: x3 = 3x (600mm)
  • Connettori periferici 4 pin 4
  • Tensione di ingresso 100-240Vac
  • Serie MWE Bronze Series
  • Protezioni OVP
  • Protezioni OPP
  • Dimensioni (L x P x A) 140 x 150 x 86 mm
  • Protezioni SCP
  • Protezioni UVP
  • Modello MPX-6501-ACAAB
  • Protezioni OTP
  • Tempo di mantenimento 16ms at 80% Load
  • Protezioni OCP
  • Nome del prodotto MWE Bronze 650
  • Corrente di ingresso 750W / 850W: 10 – 6 A​ | 1000W: 15 – 8 A
  • Normative CCC
  • Normative CE
  • Normative TUV-RH
  • Normative RCM
  • Normative EAC
  • Normative cTUVus
  • Normative FCC
  • Normative BSMI
  • Normative KC
Download
