Vertical Graphics Card Holder Kit image number 0
Vertical Graphics Card Holder Kit image number 1
Vertical Graphics Card Holder Kit image number 2
Faites-en ce que vous voulez !
Kit de support vertical pour carte graphique
  • Capacité de carte graphique One graphics card per holder
  • Exigence Requires seven PCI case slots
  • Modèle de câble riser Riser Cable PCIe 3.0
  • Assistance PCI area of your Case
  • Poids net 0.230Kg
  • Couleur(s) Dark Metallic Grey
  • Legacy Accessories
  • Remarque This product is only compatible for devices that support the PCI-E 3.0 specification. If you use this product with a motherboard that supports PCI-E 4.0, please enter into BIOS option and select PCI-E 3.0 before installation.
  • Matériaux SGCC Steel
  • Dimensions (L x l x H) 170 x 145 x 120 mm
  • Numéro de modèle MCA-U000R-KFVK00
Téléchargements
