Universal Vertical GPU Holder Kit ARGB image number 0
Universal Vertical GPU Holder Kit ARGB image number 1
Illuminating Perfection
Elevate your gaming setup with the Universal Vertical GPU Holder Kit ARGB and stand out among fellow gamers. Show off your components with pride and unlock the full potential of your gaming experience.
Ultra-flexible PCIe 4.0 Riser Cable Included
Ultra-flexible PCIe 4.0 riser cable enables high-speed data transmission with ease for tight cable routing.
Tool-less, Instantly Adjustable Design
Toollessly adjustable up to 65mm horizontally, as well as up to 30mm towards the side panel for easy installation.
Effortlessly Showcase Your Graphics Card
Bring the best out of your components by showing off your GPU.
ATX & M-ATX
COMPATIBILITY
Designed for both ATX and mATX cases, this accessory is compatible with the latest GPUs available on the market.
  • Numéro de modèle MCA-U004R-AVGBST-00
  • Couleurs) Black
  • Dimensions (L x l x H) GFX Holder Kit: 249 x 148.1 x 141.8mm (close size), GFX Holder Kit: 305 x 178.1 x 141.8mm (open size), Riser Cable: 165mm (6.19in)
  • Type de châssis pris en charge ATX, Micro ATX
  • Cartes graphiques prises en charge Any length, up to 3 slots wide
  • Modèle de câble montant Riser Cable PCIe 4.0 x16
  • Compatibilité PCIe 4.0 and older
  • Numéro de certification CE BKC24041591DC
  • Matériaux des composants PCBA, Silver Plated Copper Wire 30 AWG
  • Matériaux d'isolation PE, TPE
  • Autres matériaux ABS, PP, SGCC Steel, Nickel, Gold, Brass
  • Connecteurs PCIe x16 Male to PCIe x16 90° Female
  • Température de fonctionnement -20° to +100° Celsius
  • Emplacements PCI requis Minimum 4 PCI slots required for mounting
  • Garantie 1 year
  • Série Others
  • Accessoire principal Case Accessory
