ADDRESSABLE RGB LIGHTING
Experience vibrant and personalized lighting effects with addressable RGB, fully controllable through our in-house MasterCTRL software for seamless customization.
Même légende, bord plus tranchant
Configuration multi-ventilateurs
Connexion rapide
Installation facile
Structure de cadre creux
Roulement dynamique en boucle
Éclairage RGB adressable
Cooler Master SickleFlow edge 360 ARGB White Edition is our new addition to the renowned SickleFlow series. This fan features enlarged blades for better cooling and a hollow frame for lightweight durability. A single modular cable simplifies setup, and installation requires only 4 screws. Enjoy customizable ARGB lighting, controllable with MasterCTRL software.
A single-frame unit enhances internal airflow, effectively expelling heat and significantly improving cooling efficiency.
Uses one modular cable for lighting and power, simplifying management and improving aesthetics.
Only 4 screws are needed for a hassle-free installation.
This lightweight yet durable fan module, featuring a hollow design with triangular vents ensures efficient airflow and long-lasting performance without adding bulk to your build.
Features our loop dynamic bearing, our in-house bearings, preventing dust and oil leakage and enhancing operational stability and lifespan.
