MM310 SF6 Chun-Li Gaming Mouse image number 0
MM310 SF6 Chun-Li Gaming Mouse image number 1
MM310 SF6 Chun-Li Gaming Mouse image number 2
MM310 SF6 Chun-Li Gaming Mouse image number 3
MM310 SF6 Chun-Li Gaming Mouse image number 4
MM310 SF6 Chun-Li Gaming Mouse image number 5
The MM310 is a wired gaming mouse buffed with an innovative new feature set focused on performance This includes pro grade 12 000 DPI optical sensor
Special Edition
Cooler Master
x Capcom Street Fighter 6
The MM310 wired gaming mouse, with its exclusive
color scheme and design, weaves together the aesthetics
of Street Fighter 6 and Cooler Master's gaming expertise,
embodying the spirit of Chun-Li.
Design
Lightweight Ambidextrous Design
Optimized for right-handers with two side buttons and weighs in at 50g without exterior holes that compromise on aesthetics.
 Customizable Features
MasterPlus+ Support
New, improved software allows you to remap controls, customize your RGBs, tune your macros, and more.
Cable
Ultraweave Cable
Super lightweight and engineered in-house to prevent cable snag when swiping.
Illumination
RGB Lighting
Give your victories some flashy good looks
with lighting on the logo and the scroll wheel.
Adjustability
Gaming Grade Sensor
Adapt to your game or playstyle with optical sensor
adjustable up to 12,000 DPI.
Performance
Upgraded Mouse Feet
New-and-improved feet made with PTFE material for low friction and high durability, which provides a smooth, fast glide with maximum responsiveness.
  • Numéro de produit MM-310-WWOL2
  • Type de poignée de souris Palm / Claw
  • Matériel de souris ABS Plastic / Rubber / PTFE
  • Couleur de la souris Special Design for SF6 Chun-Li
  • Couleur du voyant de la souris 16.7 Million RGB
  • Capteur de souris PixArt Optical Sensor
  • IPC / DPI 400-800-1,200(Default)-1600-3200-6200-12000
  • Vitesse de suivi de la souris 220 ips
  • Distance de décollage de la souris N/A
  • Taux d'interrogation de la souris 125 / 250 / 500 / 1000 MHz (Switch via software)
  • Capture d'angle Yes
  • Accélération de la souris 30g
  • Durée de vie de la souris (commutateurs L/R) Mechanical Micro Switch, 60M
  • Boutons de la souris 6
  • Connectivité Wired
  • Système d'exploitation compatible Windows8+ / macOS
  • Logiciel Yes, Cooler Master MasterPlus+ Support
  • Câble de souris Ultraweave Cable, 1.8 M (Type-C to Type-A) with Gold-plated
  • Dimensions de la souris 125.5 x 71.0 x 40.5 mm / 4.94 x 2.80 x 1.59 inches
  • Poids de la souris 50g / 0.11 lbs (w/o Cable)
  • Produit Mice
