MasterLiquid Lite 240 image number 0
MasterLiquid Lite 240 image number 1
MasterLiquid Lite 240 image number 2
MasterLiquid Lite 240 image number 3
MasterLiquid Lite 240 image number 4
Silence. Performance. All-in-One.
  • Radiator Material Aluminum
  • Pump Rated Voltage 12 VDC
  • Pump MTTF 70,000 Hours
  • Pump Connector 3-Pin
  • Cooler Type Liquid Cooler
  • CPU Socket LGA2066
  • CPU Socket LGA2011-v3
  • Fan MTTF 160,000 Hours
  • Radiator Size 240
  • Pump Dimensions 80.3 x 76 x 42.2 mm / 3.2 x 3.0 x 1.7 inch
  • Pump Noise Level < 15 dBA
  • Radiator Dimensions 277 x 119.6 x 27 mm / 10.9 x 4.71 x 1.1 inch
  • Fan Speed 650-2000 RPM (PWM) ± 10%
  • CPU Socket LGA1700
  • CPU Socket LGA1200
  • CPU Socket LGA1156
  • CPU Socket LGA1155
  • CPU Socket LGA1151
  • CPU Socket LGA1150
  • Series MasterLiquid Lite
  • CPU Socket AM5
  • CPU Socket AM4
  • CPU Socket AM3+
  • CPU Socket AM3
  • CPU Socket AM2+
  • CPU Socket AM2
  • CPU Socket FM2+
  • CPU Socket FM2
  • CPU Socket FM1
  • Fan Air Pressure 2.34 mmH2O ± 10%
  • Note For LGA 1700 mounting kits, You may obtain through the CM store, regional resellers and distributors. It's compatible with AMD AM5 although the package may not stress it.
  • Fan Airflow 66.7 CFM ± 10%
  • Product Number MLW-D24M-A20PW-R1
