MasterLiquid 360 ION White Edition image number 0
MasterLiquid 360 ION White Edition image number 1
EXPERIENCE COOLING IN HIGH DEFINITION
Gen X dual chamber design
2.1-inch LCD screen
Mobius 120P ARGB fans
ARGB Halo lighting
Highly customizable and compatible
Signature halo pump design
MLY-D36M-A24PZ-RW
Experience Cooling in High Definition
Cooler Master's latest flagship performance cooler, the MasterLiquid 360 Ion, is our first liquid cooler to feature an LCD display. The MasterLiquid 360 Ion gives you total display customization with top-tier cooling specs.
Gen X Dual Chamber Design
Our signature dual chamber pump has been refined for enhanced cooling synergy. Our impeller uses a single-piece design with improved structural strength and stability. The graphite ceramic shaft is highly sturdy and temperature resistant.
2.1-inch LCD Screen
2.1-inch LCD Screen
The Ion's pump features a 2.1-inch LCD screen, fully customizable with our MasterCtrl software. Meanwhile, Our ARGB halo lighting has been designed with the Cooler Master's signature aesthetic in mind.
DISCOVER MASTERCTRL
Highly Customizable and Compatible
Built-in features such as controllable ARGB lighting and automatic PWM adjustment are compatible with all major motherboards and allow for in-depth customization.
IN-HOUSE DESIGNED RADIATOR
Pre-installed with three Mobius 120P ARGB fans for unmatched cooling performance. The interconnecting fan blades have been designed with a balanced P/Q curve suitable for both air and liquid cooling.
TUBE CLIPS INCLUDED
ECO-FRIENDLY PACKAGING WITH ENHANCED PROTECTION
USING EPDM + IIR COMPOSITE MATERIALS
  • Numéro de produit MLY-D36M-A24PZ-RW
  • Couleur extérieure White
  • Prise CPU Intel® LGA 1851 / 1700 / 1200 / 1151 / 1150 / 1155 / 1156 socket
  • Prise CPU AMD® AM5 / AM4 Socket
  • Matériau du radiateur Aluminum
  • Dimensions du radiateur 394 x 119.6 x 27.2 mm / 15.5 x 4.7 x 1.1 inch
  • Longueur du tube 420 mm / 16.5 inch
  • Profils de pompe Addressable Gen2 RGB
  • Dimensions de la pompe 88.3 x 83.6 x 65.7 mm / 3.5 x 3.3 x 2.6 inch
  • Vitesse de la pompe 3000 RPM ± 10%
  • Pompe MTTF >210,000 Hours
  • Niveau sonore de la pompe 20 dBA
  • Connecteur de pompe 4-Pin + SATA
  • Tension nominale de la pompe 12 VDC
  • Consommation électrique de la pompe 6.75 W
  • Dimensions (L x l x H) 120 x 120 x 25 mm / 4.7 x 4.7 x 1.0 inch
  • Quantité de ventilateur 3 PCS
  • Type de LED du ventilateur Addressable Gen 2 RGB
  • Vitesse du ventilateur 0-2400 RPM ± 10%
  • Flux d'air du ventilateur 75.2 CFM (Max)
  • Niveau de bruit du ventilateur 30 dBA (Max)
  • Pression du ventilateur 3.63 mmH₂O (Max)
  • Type de roulement de ventilateur Loop Dynamic Bearing
  • De MTTF >200,000 Hours
  • Connecteur d'alimentation du ventilateur 4-Pin (PWM)
  • Tension nominale du ventilateur 12 VDC
  • Courant nominal du ventilateur 0.18A
  • Courant de sécurité du ventilateur 0.35A
  • Garantie 6 years
  • Type de refroidisseur Liquid Cooler
  • Série MasterLiquid Pro
