Hybrid M Massage Gaming Chair image number 0
Hybrid M Massage Gaming Chair image number 1
Hybrid M Massage Gaming Chair image number 2
Hybrid M Massage Gaming Chair image number 3
Hybrid M Massage Gaming Chair image number 4
Hybrid M Massage Gaming Chair image number 5
Hybrid M Massage Gaming Chair image number 6
Hybrid M Massage Gaming Chair image number 7
Hybrid M Massage Gaming Chair image number 8
Hybrid M Massage Gaming Chair image number 9
Hybrid M Massage Gaming Chair image number 10
Hybrid M Massage Gaming Chair image number 11
Hybrid M Massage Gaming Chair image number 12
Hybrid M is the continuation of our Hybrid 1’s innovative design that bridges the void between work and play.
Relaxation at Your Command
Say goodbye to the perils of prolonged sitting! The Hybrid M Chair is the game-changer you've been waiting for, designed to tackle the muscle pain and discomfort that plague gamers and office warriors alike.
Massage Control App
CUSTOMIZE YOUR MASSAGE YOUR WAY
With the Hybrid M App, you're in control. Record and personalize your massage programs effortlessly or simply use the built-in joystick in the armrest to adjust your massage. Whether you crave a soothing, stress-relieving session or a powerful, invigorating massage, it's all at your fingertips.
*Android Playstore App in development.
Our Achievements
AWARDS
Built-in Massage
NO CORDS, NO LIMITS, MASSAGE ANYWHERE
Unrivaled freedom with the Hybrid M, discover the experience.
Comfort
ADJUSTABLE NECK SUPPORT
Comfort
UNIBODY COLD MOLDED FOAM
75MM
SILENT CASTER
Adjustability
3D ARMREST
4CLASS
GAS LIFT
Quick Stow Magnetic  Lumbar Support
Comfort
Hybrid M's Magnetic Lumbar Support provides a convenient solution for comfort and support. With fast magnetic height adjustment, users enjoy personalized comfort at their fingertips. During the massage function, the lumbar support can be swiftly stowed away under the seat, keeping it out of sight but always close by. Experience unparalleled convenience, functionality, and ergonomic support with Hybrid M's Magnetic Lumbar Support System.
Premium Steel Frame  And Aluminum Base  Construction
Materials
Made from a rock-steady steel frame in combination with a premium aluminum base, the Hybrid M is built with high-quality materials that is not only reliable, but will last for years on end.
Video Tutorial
EASY SETUP & CUSTOMIZATION
The official step-by-step guide to assembling your new Hybrid M Chair and customizing it to perfection using the Cooler Master app.
Chair Recommendation
TABLE OF MEASURES
  • Numéro de produit CMI-GCHYBM-BK
  • Couleur Black
  • Plage de hauteur totale 137-147 cm / 53.9"-57.8"
  • Hauteur du dossier 78 cm / 30.7"
  • Largeur du dossier 54 cm / 21.3"
  • Accoudoir à accoudoir 75 cm / 29.5"
  • Largeur du siège (y compris les côtés) 61 cm / 24.0"
  • Coin salon 61 cm / 24.0"
  • Profondeur du siège 54 cm / 21.3"
  • Diamètre de la base 68 cm / 26.8"
  • Épaisseur de la plaque d'acier 1.5 mm
  • Réglage de l'accoudoir 29-36 cm / 11.4"-14.2"
  • Du sol au dessus du siège 48-58 cm / 18.9"-22.8"
  • Réglage de la hauteur 10 cm / 3.9"
  • Incliner 90-120 degree
  • Accoudoir 3D
  • Appui-tête Integrated headrest (up/down)
  • Soutien lombaire Magnetic lumbar support
  • Matériau extérieur Backrest: MuscleFlex® Mesh
  • Matériau extérieur Seatbase: Perforated PU
  • Matériau intérieur High density cold-molded foam
  • Matériau du cadre Steel
  • Base (jambe) Aluminum
  • Roulette 75 mm / 3.0"
  • Ascenseur à gaz Class 4
  • Max. Charge de poids 120 kg / 265 lbs
  • Garantie 2 years
  • Type de chaise Hybrid Series
  • Produit Gaming Chair
