GM27-FQS ARGB 30th Anniversary Edition image number 0
GM27-FQS ARGB 30th Anniversary Edition image number 1
GM27-FQS ARGB 30th Anniversary Edition image number 2
GM27-FQS ARGB 30th Anniversary Edition image number 3
GM27-FQS ARGB 30th Anniversary Edition image number 4
GM27-FQS ARGB 30th Anniversary Edition image number 5
GM27-FQS ARGB 30th Anniversary Edition image number 6
GM27-FQS ARGB 30th Anniversary Edition image number 7
GM27-FQS ARGB 30th Anniversary Edition image number 8
GM27-FQS ARGB 30th Anniversary Edition image number 9
GM27-FQS ARGB 30th Anniversary Edition image number 10
GM27-FQS ARGB 30th Anniversary Edition image number 11
GM27-FQS ARGB 30th Anniversary Edition image number 12
GM27-FQS ARGB 30th Anniversary Edition image number 13
GM27-FQS ARGB 30th Anniversary Edition image number 14
Bring Gaming to Life
The 30th Anniversary Edition of the GM27-FQS ARGB Gaming Monitor is a special limited edition product that celebrates the history of Cooler Master.
  • DCR (rapport de contraste dynamique) Yes
  • Temps de réponse 1ms (MPRT)
  • Protection des yeux Low Blue Light
  • Changement de mode Standard
  • VESA 75x75 mm
  • E/S - USB 3.0 Type A 2
  • E/S - USB 3.0 Type B 1
  • E/S - USB Type C 1
  • E/S - HDMI 2.0 2
  • Ajustement du pivot Horizontal / Vertical
  • Angle de vision (H/V) 178°/178°
  • HDR 10
  • Note ** Measure a screen brightness of 200nits without audio/USB/Card reader connection.
  • Série de moniteurs GM Series
  • Technologie VRR FreeSync Range: Yes
  • Réglage de l'inclinaison -5°~+20°
  • Rapport 16:9
  • Type d'écran Flat Series
  • Changement de mode Graphic
  • Luminosité 300 nits (Typical)
  • E/S - DP 1
  • Réglage de la hauteur 0-110 mm
  • Réglage du pivotement -15°~+15°
  • Changement de mode Movie
  • Résolution 2K QHD 2560x1440
  • Taille de l'écran 27"
  • Produit Gaming Monitor
  • Rapport de contraste 1000:1
  • Technologie VRR G-Sync Range: Yes
  • Consommation d'énergie 30W (Typ.)**
  • Gamme de couleurs DCI-P3 90%
  • Éclairage ARGB Stand
  • Technologie VRR FreeSync Premium
  • Panneau AHVA 8bit (Ultra Speed IPS)
  • Taux de rafraîchissement 165 Hz
  • Changement de mode Game
  • Changement de mode sRGB
  • Numéro de produit CMI-GM27-FQSA30TH
