Elite 690 Wood image number 0
Elite 690 Wood image number 1
Elite 690 Wood image number 2
Elite 690 Wood image number 3
Elite 690 Wood image number 4
Elite 690 Wood image number 5
Elite 690 Wood
Elite 690 Wood
Elite 690 Wood
Elite 690 Wood
Elite 690 Wood
Elite 690 Wood
Natural Aesthetics. Immersive View. Advanced Cooling.
Elite 690 Wood
The Elite 690 features dual tempered glass panels to showcase your build, while a wood-textured front accent and mesh intake blend warmth with airflow efficiency. With top and bottom ventilation for vertical cooling, it supports versatile fan and radiator setups—perfect for performance-driven or style-focused builds.
270° Panoramic Tempered Glass
Beveled glass panels create an immersive, seamless showcase of your build.
Optimized Tower with PSU Chamber
Vertical layout separates thermal zones for better airflow and cleaner cable routing.
Vertical Cooling Architecture
Up to 10 fans in a bottom-to-top layout maximize airflow and cooling.
Natural Wood Front Panel
Crafted from real wood, the front panel adds a warm, organic touch to any space.
High-Performance Radiator Support
Top 360mm and side 240mm radiator support for powerful cooling setups.
Pre-installed ARGB Fans with Sync
Includes 3 daisy-chainable ARGB fans with full motherboard lighting sync support.
Top & Bottom Mesh Ventilation
Mesh panels ensure enhanced airflow and system-wide thermal performance.
Next-Gen GPU Ready
Supports up to 425mm GPUs—ready for RTX 50 Series and beyond.
High-Speed I/O Panel
USB 3.2 Gen 2x2 Type-C and dual USB 3.0 ports for blazing-fast connectivity.
  • Numéro de modèle Black: E690-KHNN-S00, White: E690-WHNN-S00
  • Couleur(s) Black / White
  • Matériaux – Panneau avant Tempered Glass + Wood
  • Matériau – Panneau latéral (gauche) Tempered Glass
  • Matériau – Panneau latéral (droit) Steel
  • Dimensions (L x l x H) 434 x 218 x 454 mm (Incl. Protrusions), 430 x 218 x 435 mm (Excl. Protrusions)
  • Volume 42.93 L (Liters Incl. Protrusions)
  • Cartes mères compatibles ITX / Micro-ATX / ATX
  • Slots d'extension 7
  • Baies de lecteur 5,25" 0
  • Baies de lecteur 3,5" 1 (Max. 2)
  • Baies de lecteur 2,5" 1 (Max. 2)
  • Panneau E/S – Ports USB 1 x USB Type C 20Gbps, 2 x USB 3.0
  • Panneau E/S – Entrée / Sortie audio 1x 3.5mm Combo
  • Ventilateurs préinstallés – Arrière 1x 120mm ARGB PWM
  • Ventilateurs préinstallés – montage latéral 2x 120mm ARGB PWM reverse fan
  • Support de ventilateur – Haut 2x 140mm / 3x 120mm
  • Support de ventilateur – Arrière 1x 120mm
  • Support de ventilateur – Montage latéral 2x 120mm
  • Support de ventilateur - Bas 3x 120mm
  • Compatibilité radiateur – Haut 120 / 240 / 360 (Max height 45mm)
  • Support de radiateur – Bas 120 / 240 / 360mm
  • Support de radiateur – Montage latéral 120 / 240mm
  • Espace disponible - Ventirad CPU 170mm
  • Espace disponible – Alimentation 250mm
  • Espace disponible – Carte graphique 425mm
  • Prise en charge de l'alimentation ATX
  • Garantie 2 years
  • Taille Mid Tower
  • Série Elite Series
