Elite 302 Lite image number 0
Elite 302 Lite image number 1
Elite 302 Lite image number 2
Elite 302 Lite image number 3
Elite 302 Lite image number 4
Elite 302 Lite
Elite 302 Lite
Elite 302 Lite
Elite 302 Lite
Elite 302 Lite
Effortless Efficiency
Elite 302 Lite
High in value and attention to detail, Cooler Master’s Elite 302 lite offers users a cost effective, space conscious solution to gaming and computing needs.
Elite 302 features a large intake grill to ensure a smooth, and efficient running system. The fully black coating and included PSU cover allows for clean builds that are visually appealing as well as functional.
Tool-Less Magnetic Front Panel
Quick and easy maintenance with a tool-free magnetic mesh front panel — engineered for airflow and effortless access.
Ready For High-Performance Cooling
Accommodates up to 6 fans and supports 280mm or 360mm radiators to keep your system performing at its peak.
Breathable PSU Shroud
Ventilated power supply cover supports both active and passive cooling —
offering flexibility and thermal efficiency.
Front I/O USB Type-C Support
Modern connectivity with a built-in USB Type-C port for faster, streamlined data transmission.
  • Numéro de modèle Black: E302L-KGNN-S00​, White: E302L-WGNN-S00​
  • Couleur extérieure Black, White
  • Matériaux – Extérieur Steel
  • Matériaux – Panneau latéral (droite / gauche) TG / Steel
  • Dimensions (L x l x H) 390 x 203.5 x 430mm​ (Incl. Protrusions), 377 x 203.5 x 410mm​ (Excl. Protrusions)
  • Volume (protubérances incluses) 34.13L​
  • Cartes mères compatibles Mini-ITX, Micro-ATX
  • Slots d'extension 4
  • Baies de lecteur 5,25" N/A
  • Baies de lecteur 3,5" 1
  • Baies de lecteur 2,5" 1 (Max. 2)
  • Panneau E/S – Ports USB 1x USB 3.2 Gen1 Type A, 1x USB 3.2 Gen1 Type C​
  • Panneau E/S – Entrée / Sortie audio 1x 3.5mm Combo
  • Support de ventilateur - Avant 3x 120mm
  • Support de ventilateur – Haut 2x 120mm / 2x 140mm
  • Support de ventilateur – Arrière 1x 120mm
  • Ventilateurs préinstallés – Avant N/A
  • Ventilateurs préinstallés – Haut N/A
  • Ventilateurs préinstallés – Arrière 1x 120mm Black Fan
  • Support de radiateur – Avant 120 / 240 / *360 mm (*Supported within 60mm thickness)​
  • Compatibilité radiateur – Haut 120 / 140 / 240 / 280mm
  • Support de radiateur – Arrière 120mm
  • Espace disponible - Ventirad CPU 163.5mm
  • Espace disponible – Alimentation 160mm
  • Dégagement - Carte graphique 365mm (without front fans & radiator)
  • Gestion des câbles 18.5mm
  • Filtres à poussière Top / Bottom / Front
  • Prise en charge de l'alimentation ATX
  • Garantie 2 years
  • Taille Mini Tower
  • Série Elite Series
