Caliber R1S CAMO Gaming Chair image number 0
Caliber R1S CAMO Gaming Chair image number 1
Caliber R1S CAMO Gaming Chair image number 2
Caliber R1S CAMO Gaming Chair image number 3
Caliber R1S CAMO Gaming Chair image number 4
Caliber R1S CAMO Gaming Chair image number 5
Caliber R1S CAMO Gaming Chair image number 6
Caliber R1S CAMO Gaming Chair image number 7
Caliber R1S CAMO Gaming Chair image number 8
Caliber R1S CAMO Gaming Chair image number 9
Caliber R1S CAMO Gaming Chair image number 10
Caliber R1S CAMO Gaming Chair image number 11
Caliber R1S CAMO Gaming Chair image number 12
Caliber R1S CAMO Gaming Chair image number 13
Caliber R1S CAMO Gaming Chair image number 14
Caliber R1S CAMO Gaming Chair image number 15
Caliber R1S CAMO Gaming Chair image number 16
Caliber R1S CAMO Gaming Chair image number 17
Caliber R1S CAMO Gaming Chair image number 18
Caliber R1S CAMO Gaming Chair image number 19
Caliber R1S CAMO Gaming Chair image number 20
Caliber R1S CAMO Gaming Chair image number 21
Caliber R1S CAMO Gaming Chair image number 22
Caliber R1S CAMO Gaming Chair image number 23
Caliber R1S CAMO Gaming Chair image number 24
Caliber R1S CAMO Gaming Chair image number 25
Caliber R1S CAMO Gaming Chair image number 26
Caliber R1S CAMO Gaming Chair image number 27
Caliber R1S CAMO Gaming Chair image number 28
Caliber R1S CAMO Gaming Chair image number 29
Caliber R1S CAMO Gaming Chair image number 30
Caliber R1S CAMO Gaming Chair image number 31
Caliber R1S CAMO Gaming Chair image number 32
Caliber R1S CAMO Gaming Chair image number 33
Caliber R1S CAMO Gaming Chair image number 34
Caliber R1S CAMO Gaming Chair image number 35
Caliber R1S CAMO Gaming Chair image number 36
Caliber R1S CAMO Gaming Chair image number 37
Caliber R1S CAMO Gaming Chair image number 38
Caliber R1S CAMO Gaming Chair image number 39
Caliber R1S CAMO Gaming Chair image number 40
Caliber R1S CAMO Gaming Chair image number 41
Caliber R1S CAMO Gaming Chair image number 42
Caliber R1S CAMO Gaming Chair image number 43
Caliber R1S CAMO Gaming Chair image number 44
Caliber R1S CAMO Gaming Chair image number 45
Caliber R1S CAMO Gaming Chair image number 46
Caliber R1S CAMO Gaming Chair image number 47
It's Time To Level Up
Gain more XP, no more muscle stiffness! With an ergonomic design and premium PU material, Caliber R1S is your perfect match for long hours of missions
Couleur
Acheter maintenant
  • Numéro de produit CMI-GCR1S-PRC, CMI-GCR1S-BKC, CMI-GCR1S-PKC
  • Couleur CM CAMO, Dark Knight CAMO, SAKURA CAMO
  • Plage de hauteur totale 125-133 cm / 49.2"-52.4"
  • Hauteur du dossier 82 cm / 32.3"
  • Largeur du dossier 57 cm / 22.4"
  • Accoudoir à accoudoir 75 cm / 29.5"
  • Largeur du siège (y compris les côtés) 53 cm / 20.9"
  • Coin salon 37 cm / 14.5"
  • Profondeur du siège 57 cm / 22.4"
  • Diamètre de la base 70 cm / 27.6"
  • Épaisseur de la plaque d'acier 1.2 mm
  • Réglage de l'accoudoir 28-36 cm / 11.0"-14.2"
  • Du sol au dessus du siège 45-53 cm / 17.7"-20.9"
  • Réglage de la hauteur 8 cm / 3.1"
  • Incliner 90-180 degree
  • Accoudoir 1D, 2D (Rose White)
  • Appui-tête Ergonomic Pillow
  • Soutien lombaire Ergonomic
  • Matériau extérieur Perforated PU
  • Matériau intérieur Backrest: cut foam, Seatbase: cold molded foam
  • Matériau du cadre Steel
  • Base (jambe) Nylon
  • Roulette 60 mm / 2.4"
  • Ascenseur à gaz Class 4
  • Poids net 21.5 kg / 47.4 lbs
  • Poids brut 24 kg / 52.9 lbs
  • Max. Charge de poids 150 kg / 330 lbs
  • Garantie 1 year
  • Produit Gaming Chair
  • Type de chaise Caliber R1 Series
