Caliber E1 Gaming Chair image number 0
Caliber E1 Gaming Chair image number 1
Caliber E1 Gaming Chair image number 2
Caliber E1 Gaming Chair image number 3
Caliber E1 Gaming Chair image number 4
Caliber E1 Gaming Chair image number 5
Caliber E1 Gaming Chair image number 6
Caliber E1 Gaming Chair image number 7
Caliber E1 Gaming Chair image number 8
Caliber E1 Gaming Chair image number 9
Caliber E1 Gaming Chair image number 10
Caliber E1 Gaming Chair image number 11
Caliber E1 Gaming Chair image number 12
Caliber E1 Gaming Chair image number 13
Caliber E1 Gaming Chair image number 14
Caliber E1 Gaming Chair image number 15
Caliber E1 Gaming Chair image number 16
Caliber E1 Gaming Chair image number 17
Caliber E1 Gaming Chair image number 18
Caliber E1 Gaming Chair image number 19
Caliber E1 Gaming Chair image number 20
Caliber E1 Gaming Chair image number 21
Caliber E1 Gaming Chair image number 22
Caliber E1 Gaming Chair image number 23
Caliber E1 Gaming Chair image number 24
Caliber E1 Gaming Chair image number 25
Caliber E1 Gaming Chair image number 26
Caliber E1 Gaming Chair image number 27
Caliber E1 Gaming Chair image number 28
Caliber E1 Gaming Chair image number 29
Caliber E1 Gaming Chair image number 30
Caliber E1 Gaming Chair image number 31
Caliber E1 Gaming Chair image number 32
Caliber E1 Gaming Chair image number 33
Caliber E1 Gaming Chair image number 34
Caliber E1 Gaming Chair image number 35
Caliber E1 Gaming Chair image number 36
Caliber E1 Gaming Chair image number 37
Caliber E1 Gaming Chair image number 38
Caliber E1 Gaming Chair image number 39
Caliber E1 Gaming Chair image number 40
Caliber E1 Gaming Chair image number 41
Comfort Never Looked Better
The New Caliber E1 brings you the extremely comfort you need to thoroughly enjoy gaming and working.
Couleur
Acheter maintenant
The New Caliber E1 gaming chair brings you the comfort you need to thoroughly enjoy gaming and working. With all the necessary ergonomic adjustments along with a comfortable and breathable PU leather material, the E1 is a great value addition to your setup.
Ergonomic Design
Ergonomic Design
Freely adjust the sitting angle with the reclining backrest to find your perfect resting position. With a height-adjustable gas lift, the Caliber E1 helps to minimize fatigue and maximize the comfort of your gaming or work sessions.
Head and Lumbar Pillows
The headrest and lumbar pillow will provide you with the best level of comfort to reduce back pain and alleviate neck strain.
BREATHABLE PU MATERIAL
RECLINE ADJUSTMENT
SPLASH / DUST OUT
  • Numéro de produit Purple: CMI-GCE1-PR, Black: CMI-GCE1-BK, Pink: CMI-GCE1-PK
  • Couleur Purple / Black / Pink
  • Plage de hauteur totale 114-122 cm / 44.9"-48.0"
  • Hauteur du dossier 74 cm / 29.1"
  • Largeur du dossier 53 cm / 20.9"
  • Accoudoir à accoudoir 68 cm / 26.8"
  • Largeur du siège (y compris les côtés) 54 cm / 21.3"
  • Coin salon 54 cm / 21.3"
  • Profondeur du siège 51 cm / 20.0"
  • Diamètre de la base 70 cm / 27.6"
  • Du sol au dessus du siège 45-53 cm / 17.7"-20.9"
  • Réglage de la hauteur 8 cm / 3.1"
  • Incliner 90-135 degree
  • Accoudoir Fixed
  • Appui-tête Ergonomic Pillow
  • Soutien lombaire Ergonomic
  • Matériau extérieur Perforated PU
  • Matériau intérieur High Density Foam
  • Matériau du cadre Plywood
  • Base (jambe) Nylon
  • Roulette 60 mm / 2.4"
  • Ascenseur à gaz Class 4
  • Poids net 17.6 kg / 38.8 lbs
  • Poids brut 20.1 kg / 44.3 lbs
  • Max. Charge de poids 120 kg / 265 lbs
  • Garantie 1 year
  • Produit Gaming Chair
  • Type de chaise Caliber E1 Series
