Hyper 212 3DHP Black image number 0
Hyper 212 3DHP Black image number 1
Hyper 212 3DHP Black image number 2
Hyper 212 3DHP Black image number 3
Hyper 212 3DHP Black image number 4
Legendary Cooling, Reinvented​
● Cooler Master Proprietary 3DHP technology​
● Superior thermal performance​
● Pre-installed ring blade fan​
● Larger contact surface area​
Cooler Master Proprietary 3DHP Technology​
3DHP technology redefines heat pipe design by adding a third dimension—an extra pipe that fills the dead zone in standard U-shaped layouts. This added connection improves heat transfer in a slimmer, more efficient design.​
It delivers the cooling power of a four-pipe solution with a more streamlined layout—giving you lower temps, quieter fans, and more flexibility, whether you’re building for silence or pushing your system to the limit.​
Quieter. Stronger. Smarter.​
Fewer pipes, better performance. 3DHP’s efficient heat transfer reduces radiator turbulence and lowers fan noise across the system. Whether you’re building for silence or tuning for peak output, 3DHP delivers.​
The Advanced 3DHP Internal Structure​
3DHP heat pipes use a hybrid internal structure that combines sintered powder and grooved channels in varying textures and sizes. Each section is optimized for a specific phase—evaporation, condensation, or liquid return—resulting in more efficient heat transfer than traditional designs.​
*Image for reference only; actual internal configuration may vary in the final product design.
Excellent Thermal Dissipation​
Keeps temperatures lower under the same CPU workload, helping maintain system stability and long-term reliability.​
Pre-Installed Ring Blade Fan​
The included Mobius 120 fan features a ring blade design that cuts high-frequency noise and keeps operation smooth and quiet—especially when paired with the 3DHP module.​
Larger Contact Surface for Maximum Heat Transfer​
Unlike most four-pipe coolers with direct contact, our solid copper base covers more surface area. Combined with wider 3DHP heat pipes, it ensures efficient heat transfer from the CPU to the cooling array.​
Sleek, Modern Design​
Finished in matte black with clean lines and subtle contours, Hyper 212 3DHP Black integrates seamlessly into modern setups.​
  • Nom du produit Hyper 212 3DHP Black
  • Numéro de produit MAY-T2HP-217PK-R1
  • Couleur extérieure Black
  • Prise CPU Intel® LGA 1851 / 1700 / 1200 / 1151 / 1150 / 1155 / 1156 socket
  • Prise CPU AMD® AM5 / AM4 Socket
  • Dimensions (L x l x H) 133 x 86 x 158 mm | 5.2 x 3.4 x 6.2 inch
  • Matériau du dissipateur de chaleur 2 x 3DHP / Aluminum Fins
  • Dimensions du ventilateur (L x L x H) 120 x 120 x 25mm
  • Profils de fans Non-LED
  • Quantité de ventilateur 1 PC
  • Vitesse du ventilateur 0-2050 RPM​ ± 10%
  • Flux d'air du ventilateur 107.2 m³/h (63.1 CFM)
  • Pression du ventilateur 2.69 mmH₂O (Max)
  • De MTTF >200,000 Hours
  • Niveau de bruit du ventilateur 22.6 dBA (Max)
  • Type de roulement de ventilateur Loop Dynamic Bearing
  • Connecteur d'alimentation du ventilateur 4-Pin (PWM)
  • Tension nominale du ventilateur 12 VDC
  • Courant nominal du ventilateur 0.12 A
  • Courant de sécurité du ventilateur 0.35A
  • Consommation électrique du ventilateur 1.44 W
  • Garantie 5 years
  • Série Hyper
  • Taille du ventilateur 120
  • Caloducs 2
  • Type de refroidisseur Air Cooler
