指南與資源中心
探索完整的教學指南、操作手冊與豐富資源,全面提升你的組裝體驗。
Cooler Master 為 Intel Core Ultra 200S 處理器帶來次世代散熱技術
Intel 全新推出 Core Ultra 200S 系列處理器,Cooler Master 也同步準備好完整支援的新一代散熱解決方案,全面相容於 LGA1851 插槽。想了解 Cooler Master 如何透過先進散熱技術,為這款次世代處理器提供穩定高效的極致效能?繼續閱讀,探索我們的散熱陣容如何讓系統發揮最大潛力。
COOLING X:搭載雲端伺服器等級的散熱效能
30 年來,Cooler Master 一直是工業級伺服器散熱領域的領導者,同時也為遊戲玩家、創作者與電腦硬體愛好者打造各式創新 PC 組件。COOLING X 正是我們累積多年專業經驗的結晶,採用與全球頂尖伺服器與超級電腦相同等級的工業級材質、熱設計與工程技術,打造出一款前所未有的預組電腦系統,重新定義效能與靜音的極致體驗。
簡要概覽:人工智慧、機器學習、深度學習與人工智慧個人電腦的重要性日益提升
隨著個人 AI 運算時代快速演進,我們正邁入一個全新世代的運算體驗。本文將深入探討人工智慧(AI)與 AI 電腦的核心概念,並剖析其背後所需的運算效能與硬體挑戰。Cooler Master 長期耕耘於 AI 伺服器散熱解決方案,結合產業趨勢洞察,期望為這場即將到來的 AI 個人運算轉型提供清晰的視角。我們的目標,是以專業技術與深厚經驗,打造出無縫且直覺的 AI PC 使用體驗。
What Is ATX 3.1: How Cooler Master Protects Your GPU With The Latest Standard
The main change that comes with the ATX 3.1 PSU spec is the new 12V-2x6 power connector, which fixes all the reliability issues present in the ATX 3.0 12VHPWR connector.
Best PC Fan Setups: How To Improve Your Case's Cooling
How to optimize your PC cooling performance with the best fan configuration.
WHAT IS ATX 3.0?
ATX 3.0 is a PSU specification standard released by Intel. ATX 3.0 is optimal for high-power gaming and streaming, and essential for Nvidia 40 series GPUs.
THE TECHNICAL EVOLUTION OF THE MOBIUS SERIES
Cooler Master’s in-house designed Mobius series case fans feature several technological evolutions, making them the star of the next generation of cooling technology.
WHAT IS CYBENETICS NOISE LEVEL?
Cybenetics calculates a PSU’s overall noise output by averaging testing noise measurements, and then certifying the PSU with a noise level rank.
ATX OR SFX: WHICH PSU IS RIGHT FOR YOU?
Generally, SFX PSUs are best for small form factor cases or otherwise compact machines that don’t have much space for other components like cooling systems, while ATX PSUs are for larger, regular cases.
HOW TO INSTALL A LIQUID COOLER IN YOUR PC
Installing an AIO CPU liquid cooler in your PC is pretty easy if you follow these steps.
RGB OR ARGB? WHAT'S THE DIFFERENCE?
RGB lighting is LED-based lighting that allows for more than 16 million color variations. ARGB lighting allows for more complex lighting displays via control of each individual LED.
HOW TO CHOOSE A PC CASE?
When choosing a PC case, it is important to consider the form factor, features, and aesthetics. Ensure that all components will work and fit together properly, and that the case you have selected can support the kind of tasks you want your PC to perform.
AIO LIQUID COOLING OR AIR COOLING? WHICH SHOULD YOU CHOOSE?
Air coolers and AIO liquid cooling are both effective methods for cooling your CPU. Which you choose is largely a matter of personal preference.
HOW TO SAFELY INSTALL A PSU?
Safely installing a PSU while building your PC is not too complex. If you follow the steps of this guide and your product’s instructions slowly and carefully, everything should go smoothly.
WHAT IS A PSU?
A PSU plugs into a wall outlet and converts the AC power supplied to your home into low-voltage regulated DC power to be used by your PC. As the heart that powers the entire machine, the PSU is among the most important components in your PC.
WHAT IS AN SFX PSU?
SFX is a small form factor PSU design specification. Small form factor refers to a smaller-than-usual computer component. SFX power supplies are significantly smaller than ATX PSUs.
WHAT IS AN ATX PSU?
ATX (Advanced Technology eXtended) is a specification for motherboards, PSUs, and cases. The specification defines sizing, I/O panel location, mounting points, and other factors that ensure each PC component fits together in a standardized way.
WHAT ARE POST-CONSUMER RECYCLED MATERIALS?
Post-consumer recycled (PCR) materials are made from consumer recycled materials and are used to make new products. PCR materials can be used in the composition of materials such as aluminum and plastic, and in the manufacturing of packaging, consumer electronic goods, and more.
WHAT IS 80 PLUS EFFICIENCY?
80 Plus efficiency is a certification program that proves the efficiency of PC power supply units. An 80 Plus certified unit is guaranteed to be at least 80% efficient at loads of 20%, 50%, and 100%.
HOW TO CHOOSE A PSU?
When building a PC, you need to know the 3 most important factors for choosing a PSU: wattage, form factor, and efficiency. We have compiled a list of the 3 most important factors to consider when choosing a PSU for your build.
THE POWER OF SUPERCONDUCTIVE COMPOSITE HEAT PIPES
CPU coolers are one of the most important components that ensure a powerful PC can run smoothly. The CPU is the brain of every PC and if it overheats it will cease to work properly, effectively shutting down the entire machine.
@ Cooler Master Technology Inc. (VAT: 54272387)
