X Mighty Platinum 2000 | Next Gen Might image number 0
X Mighty Platinum 2000 | Next Gen Might image number 1
X Mighty Platinum 2000 | Next Gen Might image number 2
X Mighty Platinum 2000 | Next Gen Might image number 3
UNLEASH NEXT-GEN MIGHT
Cooler Master's X Mighty Platinum power supply ensures next-level performance. Experience the pinnacle of power with X Mighty Platinum.
Unleash Next-Gen Might
The X Mighty Platinum is a powerhouse blending high-capacity performance, top-tier industrial-grade IC components, and sophisticated interleaved PFC topology. This PSU is engineered to meet the demanding needs of server and artificial intelligence industries, featuring dual 12V-2x6 connectors designed for rigorous, high-performance applications.
AI-Ready Dual GPU Support with Color-Coded Precision
Supports dual 12V-2x6 connectors for dual GPU configurations, ideal for AI and machine learning workloads. Features dual-color connects (black and purple) to ensure correct installation.
Infineon Industrial-Grade Chipset for Enduring Reliability
Infineon industrial-grade chipset ensures long-lasting reliability
Active Bridge Rectifier for Boosted Efficiency and Stability
Active bridge rectifier for enhanced power efficiency and stability
Advanced Aluminum Design for Superior Cooling and Durability
Advanced aluminum thermal structure ensures excellent heat dissipation and durability
Premium Japanese Capacitors for Silent, Long-Lasting Performance
High-quality Japanese capacitors improve longevity and reduce electrical noise
PMBus Support for Enterprise-Grade Performance Monitors
PMBus port support offers enterprise-grade performance monitoring capability
仕様
  • 製品型番 MPS-K001-AFBP
  • 電源規格 ATX 12V バージョン3.1
  • PFC アクティブPFC
  • 入力電圧 115 - 240V (115 - 240V for 1600W / 200 - 240V for 2000W)
  • 入力電流 16A (Max)
  • 入力周波数 50-60Hz
  • 筐体サイズ (L x W x H) 180 x 150 x 86 mm
  • 冷却ファンサイズ 120mm
  • ファンベアリング FDB
  • ファン回転数 2500 RPM
  • 変換効率 ≥ 94% @ Typical Load
  • 80 PLUS 認証 80 PLUS Platinum of EU Internal
  • Erp 2014 Lot 3 はい
  • 動作温度 0-50°C
  • Power Good シグナル 100 - 150 ms
  • ホールドアップタイ��� ≥ 16ms
  • MTBF >100,000 時間
  • 保護回路 OPP/ OVP/ OTP/ OCP/ SCP/ UVP/ Surge & Inrush Protection
  • 安全認証 cUL, TUV, CE, FCC, BSMI, CCC, EAC, RCM, UKCA/BIS, KC (based on region's request.)
  • ATX 24 PIN コネクタ 1
  • EPS 4+4 PIN コネクタ 1
  • EPS 8 PIN コネクタ 1
  • SATA コネクタ 12
  • PERIPHERAL 4 PIN コネクタ 4
  • PCI-E 6+2 PIN コネクタ 4
  • 12V-2x6 PIN コネクタ 2
  • USB 10P Connector 1
  • PMBus 5 Pin Connector 1
  • シリーズ X Series
  • 80 PLUS認証 Platinum
  • モ���ュラー Fully Modular
  • Category Above 750W
  • Watts 2000W
