RGB LED Controller image number 0
RGB LED Controller image number 1
RGB LED Controller image number 2
RGB LED Controller
RGB LED Controller
RGB LED Controller
Cool with Your Color
RGB LED Controller
RGB LED Controller
仕様
  • RGB LED Controller - Dimensions 90 x 53 x 14 mm / 3.54 x 2.08 x 0.55 inch
  • 材質 Plastic
  • Control Method Cooler Master Software
  • Input Connector SATA Power
  • Output Channel Voltage 12V
  • Output Channels 4
  • Lighting Mode Static
  • 付属品 450 mm Extension Cable x 4
  • Interface USB connectors (9 Pin)
  • 付属品 600 mm Extension Cable x 1
  • Lighting Mode Breathing
  • Output Channels Port 1, 2 for Frequency Control
  • 材質 PCB
  • Lighting Mode Color Cycle
  • Lighting Mode Stars
  • メーカー保証 5 years
  • Lighting Mode Customize
  • Lighting Mode Multilayer
  • クーラー分類 RGB Accessories
  • Lighting Mode Turn LED Off
  • Lighting Mode Mirage (Frequency Control)
  • 重量 122g
  • 製品シリーズ RGB Accessories
  • 製品型番 MFY-RCSN-NNUDK-R1
