MWE 450 Bronze V2 Full Range image number 0
MWE 450 Bronze V2 Full Range image number 1
MWE 450 Bronze V2 Full Range image number 2
MWE 450 Bronze V2 Full Range image number 3
MWE 450 Bronze V2 Full Range image number 4
MWE 450 Bronze V2 Full Range image number 5
MWE 450 Bronze V2 Full Range image number 6
MWE 450 Bronze V2 Full Range image number 7
MWE 450 Bronze V2 Full Range image number 8
MWE 450 Bronze V2 Full Range image number 9
80 PLUS BRONZE認証 電源ユニット
The MWE Bronze V2 offers 80 PLUS Bronze certification, guaranteeing an average efficiency of 85% at typical load. The DC-to-DC + LLC circuit design...
80 PLUS BRONZE CERTIFIED
120MM HDB FAN
DC-TO-DC CIRCUIT DESIGN
SINGLE +12V RAIL
FLAT BLACK CABLES
For many PC Builders with aesthetics in mind, cabling can be one of the most troublesome parts of assembling a PC. Cables can be confusing, too short or too long, and they almost never look good. The MWE Bronze - V2 uses flat and flexible black cables to help deal with these problems. These cables are more discrete and flexible, making them easier to implement into your system while taking up less space. This is especially useful for smaller cases and preserving airflow.
TECH SPECS
CABLE LENGTH
TECH SPECS
OUTPUT RATING
5 YEAR WARRANTY
The many processes required by a power supply unit in order to take power directly from the wall or other fixed power source, convert it to the correct output required by the connected components, and then distribute that power to said components safely can be full of risks. This is why it's important for a PSU to have the right protections and regulations to ensure this process runs correctly. The MWE Bronze - V2 is a safe, reliable product and as such Cooler Master is happy to offer a standard 5 year manufacturing warranty for all units in the series.
仕様
  • PFC アクティブPFC
  • 入力周波数 50-60Hz
  • MB 24 PIN コネクタ 1
  • Erp 2014 Lot 3 はい
  • EPS 4+4 PIN コネクタ 1
  • Power Good シグナル 100 - 500 ms
  • MTBF >100,000 時間
  • 冷却ファンサイズ 120mm
  • 80 PLUS 認証 80 PLUS Bronze
  • Category Under 500W
  • モジュラー Non Modular
  • ファンベアリング HDB
  • 変換効率 85% Typically
  • 80 PLUS認証 Bronze
  • 入力電圧 100-240V
  • PCI-E 6+2 PIN コネクタ 2
  • SATA コネクタ 6
  • ファン回転数 1500 RPM
  • 動作温度 40°C
  • シリーズ MWE Bronze Series
  • 電源規格 ATX 12V V2.52
  • PERIPHERAL 4 PIN コネクタ 3
  • 保護回路 OVP
  • 保護回路 OPP
  • ホールドアップタイム >14ms at 100% Full Load
  • ファン騒音値 @ 20% 11.18 dBA
  • 保護回路 SCP
  • 筐体サイズ (L x W x H) 140 x 150 x 86 mm
  • 保護回路 UVP
  • ファン騒音値 @ 100% 29.5 dBA
  • ファン騒音値 @ 50% 17.1 dBA
  • 保護回路 OTP
  • 入力電流 8-4A
  • 安全認証 CCC
  • 安全認証 CE
  • 安全認証 TUV-RH
  • 安全認証 RCM
  • 安全認証 EAC
  • 安全認証 cTUVus
  • 安全認証 FCC
  • 安全認証 BSMI
  • 安全認証 KC
  • 安全認証 CB
  • 製品型番 MPE-4501-ACAAW
