MasterLiquid ML360 SUB-ZERO image number 0
MasterLiquid ML360 SUB-ZERO image number 1
Cooler Master’s MasterLiquid ML360 SUB-ZERO is amongst the first Thermoelectric Cooling (TEC) AIO liquid coolers powered by Intel® Cryo Cooling Tech
Improved and Enhanced Pump
Newly Designed Pump traditionally used in DIY cooling systems with high performance motor that has an enhanced repeller to dissipated heat from the TEC in a more efficiently.
KEY FEATURES
Sub-Ambient Cooling
Specifically designed using Thermoelectric Unit (TEC) to cool your processor and create the conditions that allow it to achieve low core count over-clocking.
Powered by Intel Cryo Cooling Technology
Designed with a simple user interface making it easy to understand and control the sub-ambient cooling potential.
Cryo-Clocking
Silicon can reach higher frequencies at lower voltages that can only be achieved through sub-ambient cooling. The concept of Cryo-Clocking is to push
2nd Generation Pump
Enhanced pump delivers higher liquid flow for exceptional heat removal.
RECOMMENDED INSTALLATION
A: Top Mounted 360 mm Radiator
B: Front Mounted Pump
To get the best performance for your system for you CPU we recommend a top installation of the 360mm radiator and a front installation of the pump. The fans are pre-installed on the radiator and pump bracket pre-attached (out-of-box).
SETTING UP OVERCLOCKING ON YOUR CPU
Overclocking your CPU doesn’t have to be complicated and can be achieved in 2 basic ways:
Overclocking through BIOS Settings
OR
Using Intel XTU Software
仕様
  • 製品型番 MLZ-D36M-A19PK-12
  • 外観カラー ブラック
  • 対応CPUソケット LGA1200
  • Waterblock Dimensions 89 x 79 x 86.7 mm / 3.5 x 3.1 x 3.4 inch
  • ラジエーター材質 アルミニウム
  • ラジエーター寸法 394 x 119.6 x 27.2 mm
  • ポンプ寸法 57.3 x 57.3 x 92.2 mm
  • ポンプ寿命(MTTF) 198,000 時間
  • ポンプ騒音値 < 35 dBA
  • 電源コネクタ 4-Pin
  • ポンプ定格電圧 12 VDC
  • ポンプ定格電流 1.0 A
  • ポンプ消費電力 13.8W (Max)
  • 製品寸法 (L x W x H) 120 x 120 x 25 mm
  • ファン数量 3 個
  • ファンLED Non-LED
  • ファン速度 650-1900 RPM ± 10%
  • ファン風量 59 CFM (最大)
  • ファン騒音値 8 - 26 dBA
  • ファン風圧 2.0 mmH₂O (最大)
  • ファン平均寿命 160,000 Hours
  • ファンコネクタ 4-Pin (PWM)
  • ファン定格電圧 12 VDC
  • Total Power Consumption 200 W
  • RAMクリアランス N/A
  • LED Indicator Red --- Off line
  • メーカー保証 5 年
  • クーラー分類 水冷CPUクーラー
  • 製品シリーズ MasterLiquid Maker
