MasterBox MB400L image number 0
MasterBox MB400L image number 1
MasterBox MB400L image number 2
MasterBox MB400L image number 3
MasterBox MB400L image number 4
MasterBox MB400L
MasterBox MB400L
MasterBox MB400L
MasterBox MB400L
MasterBox MB400L
Sensible by design
MasterBox MB400L
Brushed Front Panel
Brushed Front Panel
A brushed finish spans the entire front panel for an elegant and minimalistic design.
Hexagon Gleam
Hexagon Gleam
If an optional, illuminated fan is installed, the Cooler Master hexagon logo will capture light from the fan and emit a glow on the front panel.
Mesh Intakes
Mesh Intakes
Large, mesh intakes span each side of the front panel to provide additional airflow to system.
With/Without Odd Support
Depending on preference, an ODD version of the chassis is available. If an ODD is not preferred, a cleaner appearance and more cooling options on the top and front panels are supported.
Adaptable Drive Cage
The drive cage is (re)movable, able to shift toward the front to accommodate for PSU space, backwards to provide additional radiator space, or even completely removed.
Versatile Cooling Options
Support for up to six fans and front, top, and rear radiator support ensure that performance is not compromised.
Room For Upgrades
Room For Upgrades
Support for up to a 344mm graphics card, a 166mm CPU cooler, and up to a 325mm PSU in length provides room for upgrades to stay ahead of the game.
仕様
  • 製品型番 MCB-B400L-KGNN-S00
  • カラー ブラック
  • 材質 - 外装 スチール, プラスチック
  • 材質 - 左サイドパネル Tempered Glass, Steel
  • 製品寸法 (L x W x H) 411 x 218 x 410mm (TG / Incl. Protrusions), 411 x 210 x 410mm (Steel / Incl. Protrusions), 396 x 210 x 400mm (Excl. Protrusions)
  • 容積 33.26L (Excl. Protrusions)
  • 対応マザーボード Mini-ITX, Micro-ATX
  • 拡張スロット 4
  • 5.25"ドライブベイ 0
  • 3.5" ドライブベイ 2
  • 2.5" ドライブベイ 2
  • I/Oパネル - USB ポート Option 1: 2x USB 3.2 Gen 1 (USB 3.0) / Option2: 1x USB 3.2 Gen 1 (USB 3.0), 1x USB 2.0 / *options may vary per region
  • I/Oパネル - オーディオ出入力 3.5 mm コンボ x 1
  • 付属ケースファン - トップ N/A
  • 付属ケースファン - フロント N/A
  • 付属ケースファン - リア 1x 120mm Black Fan* / *options may vary per region
  • 対応ケースファン - トップ 2x 120/140mm
  • 対応ケースファン - フロント 3x 120mm, 2x 140mm (Mount behind the front plate)
  • 対応ケースファン - リア 120 mm x 1
  • 対応水冷ラジエーター - トップ 120 / 240mm
  • 対応水冷ラジエーター - フロント 120 / 140 / 240 / 280mm
  • 対応水冷ラジエーター - リア 120 mm
  • クリアランス - CPUクーラー Steel: 167mm, TG: 166mm
  • クリアランス - 電源ユニット 325mm (w/o front radiator & HDD cage)
  • クリアランス - グラフィックスカード 344mm
  • ケーブル配線機構 18-22mm
  • 対応電源ユニット Bottom Mount, ATX
  • ダストフィルター 前面, 上部, 底部
  • メーカー保証 2年
  • サイズ Mini Tower
  • シリーズ MasterBox Series
