Hybrid 1 Ergo Gaming Chair 30th Anniversary Edition image number 0
Hybrid 1 Ergo Gaming Chair 30th Anniversary Edition image number 1
Hybrid 1 Ergo Gaming Chair 30th Anniversary Edition image number 2
Hybrid 1 Ergo Gaming Chair 30th Anniversary Edition image number 3
Hybrid 1 Ergo Gaming Chair 30th Anniversary Edition image number 4
Hybrid 1 Ergo Gaming Chair 30th Anniversary Edition image number 5
Hybrid 1 Ergo Gaming Chair 30th Anniversary Edition image number 6
Hybrid 1 Ergo Gaming Chair 30th Anniversary Edition image number 7
Hybrid 1 Ergo Gaming Chair 30th Anniversary Edition image number 8
Hybrid 1 Ergo Gaming Chair 30th Anniversary Edition image number 9
Hybrid 1 Ergo Gaming Chair 30th Anniversary Edition image number 10
Hybrid 1 Ergo Gaming Chair 30th Anniversary Edition image number 11
Hybrid 1 Ergo Gaming Chair 30th Anniversary Edition image number 12
Hybrid 1 Ergo Gaming Chair 30th Anniversary Edition image number 13
Hybrid 1 Ergo Gaming Chair 30th Anniversary Edition image number 14
Hybrid 1 Ergo Gaming Chair 30th Anniversary Edition image number 15
Hybrid 1 Ergo Gaming Chair 30th Anniversary Edition image number 16
Hybrid 1 Ergo Gaming Chair 30th Anniversary Edition image number 17
Hybrid 1 Ergo Gaming Chair 30th Anniversary Edition image number 18
Hybrid 1 Ergo Gaming Chair 30th Anniversary Edition image number 19
Hybrid 1 Ergo Gaming Chair 30th Anniversary Edition image number 20
Hybrid 1 Ergo Gaming Chair 30th Anniversary Edition image number 21
Hybrid 1 Ergo Gaming Chair 30th Anniversary Edition image number 22
両方の長所を兼ね備えた
Hybrid 1 Ergo ゲーミングチェア 30周年記念エディションは、快適性を重視したオフィスチェアの利点と、サポート性に優れたレーシングシートを融合させています。
The Best of Both Worlds
In a world of comfort and expression, the 30th Anniversary Edition Hybrid 1 is a special version of the current Hybrid 1. Hybrid 1 combines the benefits of comfort-driven office chairs with support-based racing seats that allow ergonomic customization to a user’s preference for maximum airflow during longer sessions. 30th Anniversary edition is styled particularly on the front and back end of the headrest, along with a rainbow-colored pulley.
Professional and Clean
A professional office design melded together with a gaming racing chair, Hybrid 1's premium materials and clean aesthetic is perfect for blending into any type of environment such as an office environment or your personal gaming setup back at home.
MUSCLEFLEX® MESH
FULLY-ADJUSTABLE LUMBAR SUPPORT
ADJUSTABLE NECK SUPPORT
3D ARMREST
High-Density Molded Foam
Hybrid 1 is designed to offer an all-day comfortable seating experience, built with high-density molded foam that provides extra cushioning for the best sitting experience. The premium plush materials ensure you'll remain comfortable even after extended periods of sitting.
Advanced Air Ventilation
Using our exclusive cold molded-foam technology in the seat base of the Hybrid 1, air ventilation is vastly improved leading to reduced heat buildup. The premium molded foam serves as an extremely comfortable base, conforming to your body and allowing you to sit on the Hybrid 1 for even the longest of work and play days.
Premium Steel Frame and Aluminum Base Construction
Comprised with a rock-steady steel frame in combination with a premium aluminum base, the Hybrid 1 is built with high-quality materials that is not only reliable, but will last for years on end.
75mm SILENT CASTERS
Large premium caster wheels roll exceptionally well on all surfaces while producing less noise than traditional casters.
PRECISION CLASS 4 GAS LIFT
With a premium precision class 4 gas lift, Hybrid 1's height adjustments are accurate and reliable every time.
仕様
  • 製品型番 CMI-GCHYB1-BK30TH
  • カラー 30th Anniversary Edition
  • チェアの高さ 124-134 cm
  • 背もたれの高さ 78 cm
  • 背もたれの幅 54 cm
  • アームレスト間の寸法 75 cm
  • 座面の幅 61 cm
  • 座面 61 cm
  • 座面の奥行 54 cm
  • レッグフレーム直径 68 cm
  • 鋼板の厚さ 1.5 mm
  • アームレスト調整 29-36 cm
  • 床から座面トップまでの高さ 48-58 cm
  • 高さの調整範囲 10 cm
  • リクライニング 90度-180度
  • アームレスト 3D
  • ヘッドレスト 一体型ヘッドレスト(上下可動)
  • ランバーサポート ビルトイン2Dランバーサポート(上下、前後可動)
  • 表面素材 背もたれ: MuscleFlex® メッシュ
  • インナー素材 高密度 冷感成形フォーム
  • フレーム素材 スチール
  • 底部 (脚) アルミニウム
  • キャスター 75 mm
  • ガスシリンダ Class 4
  • 製品重量 26.3 kg
  • 総重量 31.2 kg
  • 最大負荷重 150 kg
  • メーカー保証 2 年
  • 製品分類 Chair
  • チェアシリーズ Hybrid Series
