ERGO L Ergonomic Gaming Chair image number 0
ERGO L Ergonomic Gaming Chair image number 1
ERGO L Ergonomic Gaming Chair image number 2
ERGO L Ergonomic Gaming Chair image number 3
ERGO L Ergonomic Gaming Chair image number 4
ERGO L Ergonomic Gaming Chair image number 5
ERGO L Ergonomic Gaming Chair image number 6
ERGO L Ergonomic Gaming Chair image number 7
ERGO L Ergonomic Gaming Chair image number 8
ERGO L Ergonomic Gaming Chair image number 9
ERGO L Ergonomic Gaming Chair image number 10
ERGO L Ergonomic Gaming Chair image number 11
ERGO L Ergonomic Gaming Chair image number 12
ERGO L Ergonomic Gaming Chair image number 13
ERGO L Ergonomic Gaming Chair image number 14
ERGO L Ergonomic Gaming Chair image number 15
ERGO L Ergonomic Gaming Chair image number 16
ERGO L Ergonomic Gaming Chair image number 17
ERGO L Ergonomic Gaming Chair image number 18
ERGO L Ergonomic Gaming Chair image number 19
ERGO L Ergonomic Gaming Chair image number 20
ERGO L Ergonomic Gaming Chair image number 21
Gaming, Boss Level
Cooler Master ERGO L is designed for the ultimate comfort that enhances your overall body sitting posture.
今すぐ購入
Work & Play Never Stops
Say yes to a chair that can take on any number of hours in front of your screen, be it for productivity or gaming. Build for utmost comfort, our Cooler Master Ergo Chair bridges the gap between performance looks and seated well-being for the champions that give their all every day. Better cooling and improved ventilation for longer sessions is provided by the breathable MuscleFlex® high tension mesh that also creates a unique suspended seating comfort with less fatigue and pressure. Get ready for work & play’s next level!
Designed for Comfort and Cooling Performance
Cast Aluminium Strength
Ergo L sports a 3D-engineered Cast Aluminium frame that synchronizes armrest with seatback reclining in a unibody design. This lightweight material doesn’t just look pristine but offers hours on hours of consistent performance and durability.
Hard Frame, Soft Core
The Ergo mesh seat and backrest undergo rigorous testing with over 20.000 cycles of abrasion, load and tensile tests. It’s rigid yet soft, subtle but powerful, the perfect companion for those who desires to be at the top of their game.
Effortless Personalization
Mesh Me Up!
Mesh Me Up!
Breathable MuscleFlex® high tension mesh is a ballistic-like material that strikes the perfect balance between strength and elasticity whilst providing uncompromised tenderness for all body shapes and weights! Tested at 100,000 cycles against impact and Technical Bulletin 117-2013 Smolder Resistance, the Cooler Master Ergo L can take a serious beating and still come out victorious. Like player, like chair.
仕様
  • 製品型番 CMI-GCEL-2019
  • カラー Black
  • チェアの高さ 120-134 cm
  • Back Height 72-77.5cm / 28.3"-30.5" (headrest included)
  • 背もたれの幅 40-50 cm
  • アームレスト間の寸法 69 cm
  • Seating Area 51cm / 20.1"
  • 座面の幅 51 cm
  • 座面の奥行 45-49 cm (adjustable)
  • レッグフレーム直径 70 cm
  • アームレスト調整 24-28 cm
  • 床から座面トップまでの高さ 48-56.5 cm
  • 高さの調整範囲 8.5 cm
  • Seat Depth Adjustability 4cm / 1.6"
  • リクライニング 90度-120度
  • アームレスト 2D (lift, forward)
  • ヘッドレスト Adjustable (lift, tilt)
  • インナー素材 High tension mesh
  • フレーム素材 Aluminum
  • Base Material Aluminum
  • キャスター 75 mm
  • ガスシリンダ Class 4
  • 製品重量 27.8 kg
  • 総重量 33.4 kg
  • 最大負荷重 200 kg
  • メーカー保証 2 年
  • 製品分類 Chair
  • チェアシリーズ Ergonomic Series
