Elite 690 Wood image number 0
Elite 690 Wood image number 1
Elite 690 Wood image number 2
Elite 690 Wood image number 3
Elite 690 Wood image number 4
Elite 690 Wood image number 5
Elite 690 Wood
Elite 690 Wood
Elite 690 Wood
Elite 690 Wood
Elite 690 Wood
Elite 690 Wood
Natural Aesthetics. Immersive View. Advanced Cooling.
Elite 690 Wood
The Elite 690 features dual tempered glass panels to showcase your build, while a wood-textured front accent and mesh intake blend warmth with airflow efficiency. With top and bottom ventilation for vertical cooling, it supports versatile fan and radiator setups—perfect for performance-driven or style-focused builds.
270° Panoramic Tempered Glass
Beveled glass panels create an immersive, seamless showcase of your build.
Optimized Tower with PSU Chamber
Vertical layout separates thermal zones for better airflow and cleaner cable routing.
Vertical Cooling Architecture
Up to 10 fans in a bottom-to-top layout maximize airflow and cooling.
Natural Wood Front Panel
Crafted from real wood, the front panel adds a warm, organic touch to any space.
High-Performance Radiator Support
Top 360mm and side 240mm radiator support for powerful cooling setups.
Pre-installed ARGB Fans with Sync
Includes 3 daisy-chainable ARGB fans with full motherboard lighting sync support.
Top & Bottom Mesh Ventilation
Mesh panels ensure enhanced airflow and system-wide thermal performance.
Next-Gen GPU Ready
Supports up to 425mm GPUs—ready for RTX 50 Series and beyond.
High-Speed I/O Panel
USB 3.2 Gen 2x2 Type-C and dual USB 3.0 ports for blazing-fast connectivity.
仕様
  • 型番 Black: E690-KHNN-S00, White: E690-WHNN-S00
  • カラー Black / White
  • 素材 - フロントパネル Tempered Glass + Wood
  • 素材 - サイドパネル(左) Tempered Glass
  • 素材 - サイドパネル(右) Steel
  • 寸法(長さ x 幅 x 高さ) 434 x 218 x 454 mm (Incl. Protrusions), 430 x 218 x 435 mm (Excl. Protrusions)
  • 容量 42.93 L (Liters Incl. Protrusions)
  • 対応マザーボード ITX / Micro-ATX / ATX
  • 拡張スロット 7
  • 5.25インチドライブベイ 0
  • 3.5インチドライブベイ 1 (Max. 2)
  • 2.5インチドライブベイ 1 (Max. 2)
  • I/Oパネル - USBポート 1 x USB Type C 20Gbps, 2 x USB 3.0
  • I/Oパネル - オーディオ入力 / 出力 1x 3.5mm Combo
  • プリインストールファン - リア 1x 120mm ARGB PWM
  • プリインストールファン - サイドマウント 2x 120mm ARGB PWM reverse fan
  • ファン対応 - 上部 2x 140mm / 3x 120mm
  • ファン対応 - リア 1x 120mm
  • ファン対応 - サイドマウント 2x 120mm
  • ファン対応 - 底面 3x 120mm
  • ラジエーター対応 - 上部 120 / 240 / 360 (Max height 45mm)
  • ラジエーター取り付け対応 - 底面 120 / 240 / 360mm
  • ラジエーター対応 - サイドマウント 120 / 240mm
  • クリアランス - CPUクーラー 170mm
  • クリアランス - 電源ユニット 250mm
  • クリアランス - グラフィックスカード 425mm
  • 電源対応 ATX
  • 保証 2 years
  • サイズ Mid Tower
  • シリーズ Elite Series
