Cooler Master x Simucube 2 Pro image number 0
Cooler Master x Simucube 2 Pro image number 1
Cooler Master x Simucube 2 Pro image number 2
Cooler Master x Simucube 2 Pro image number 3
Cooler Master x Simucube 2 Pro image number 4
Cooler Master x Simucube 2 Pro image number 5
The Cooler Master x Simucube 2 Pro Co-brand Direct Drive Wheelbase represents a new cutting-edge advancement in sim racing gear designed for elite racers and dedicated enthusiasts.
The Cooler Master x Simucube 2 Pro Wheelbase revolutionizes the racing simulation experience with its unparalleled precision and immersive force feedback, driven by a high-torque, brushless motor.
Engineered for excellence, this wheelbase redefines expectations, offering an unmatched level of realism and engagement in the virtual racing world.
仕様
  • Dimensions (L x W x H) 270 x 130 x 130 mm (Incl. Quick Release)
  • Mounting Holes M8 x 1.25 mm (4 threaded holes)
  • Included Mounting Screws M8 x 30 mm
  • Mounting Hole Pattern DIA 145 mm
  • Flange Centering Hole DIA 110 mm
  • Wheel Base Weight 11.1 kg
  • Motor High response speed Direct Drive optimized ultra-low torque ripple motor
  • Wireless Wheel Support Yes
  • Max Torque 25 Nm
  • Max Torque Slew Rate 8.0 Nm/ms
  • Angle Sensor 22-bit absolute encoder
  • Power Supply 48 V - 360 W Rated / 450 W Peak
  • Torque Slew Rate Adjustment 1 – 8.0 Nm/ms
  • Torque Reconstruction Processing Yes
  • Static Force Reduction Yes
  • Natural Damping, Inertia and Friction Filters Yes
