Caliber R1S CAMO Gaming Chair image number 0
Caliber R1S CAMO Gaming Chair image number 1
Caliber R1S CAMO Gaming Chair image number 2
Caliber R1S CAMO Gaming Chair image number 3
Caliber R1S CAMO Gaming Chair image number 4
Caliber R1S CAMO Gaming Chair image number 5
Caliber R1S CAMO Gaming Chair image number 6
Caliber R1S CAMO Gaming Chair image number 7
Caliber R1S CAMO Gaming Chair image number 8
Caliber R1S CAMO Gaming Chair image number 9
Caliber R1S CAMO Gaming Chair image number 10
Caliber R1S CAMO Gaming Chair image number 11
Caliber R1S CAMO Gaming Chair image number 12
Caliber R1S CAMO Gaming Chair image number 13
Caliber R1S CAMO Gaming Chair image number 14
Caliber R1S CAMO Gaming Chair image number 15
Caliber R1S CAMO Gaming Chair image number 16
Caliber R1S CAMO Gaming Chair image number 17
Caliber R1S CAMO Gaming Chair image number 18
Caliber R1S CAMO Gaming Chair image number 19
Caliber R1S CAMO Gaming Chair image number 20
Caliber R1S CAMO Gaming Chair image number 21
Caliber R1S CAMO Gaming Chair image number 22
Caliber R1S CAMO Gaming Chair image number 23
Caliber R1S CAMO Gaming Chair image number 24
Caliber R1S CAMO Gaming Chair image number 25
Caliber R1S CAMO Gaming Chair image number 26
Caliber R1S CAMO Gaming Chair image number 27
Caliber R1S CAMO Gaming Chair image number 28
Caliber R1S CAMO Gaming Chair image number 29
Caliber R1S CAMO Gaming Chair image number 30
Caliber R1S CAMO Gaming Chair image number 31
Caliber R1S CAMO Gaming Chair image number 32
Caliber R1S CAMO Gaming Chair image number 33
Caliber R1S CAMO Gaming Chair image number 34
Caliber R1S CAMO Gaming Chair image number 35
Caliber R1S CAMO Gaming Chair image number 36
Caliber R1S CAMO Gaming Chair image number 37
Caliber R1S CAMO Gaming Chair image number 38
Caliber R1S CAMO Gaming Chair image number 39
Caliber R1S CAMO Gaming Chair image number 40
Caliber R1S CAMO Gaming Chair image number 41
Caliber R1S CAMO Gaming Chair image number 42
Caliber R1S CAMO Gaming Chair image number 43
Caliber R1S CAMO Gaming Chair image number 44
Caliber R1S CAMO Gaming Chair image number 45
Caliber R1S CAMO Gaming Chair image number 46
Caliber R1S CAMO Gaming Chair image number 47
It's Time To Level Up
Gain more XP, no more muscle stiffness! With an ergonomic design and premium PU material, Caliber R1S is your perfect match for long hours of missions
カラー
今すぐ購入
仕様
  • 製品型番 CMI-GCR1S-PRC, CMI-GCR1S-BKC, CMI-GCR1S-PKC
  • カラー CM CAMO, Dark Knight CAMO, SAKURA CAMO
  • チェアの高さ 125-133 cm / 49.2"-52.4"
  • 背もたれの高さ 82 cm / 32.3"
  • 背もたれの幅 57 cm / 22.4"
  • アームレスト間の寸法 75 cm / 29.5"
  • 座面の幅 53 cm / 20.9"
  • 座面 37 cm / 14.5"
  • 座面の奥行 57 cm / 22.4"
  • レッグフレーム直径 70 cm / 27.6"
  • 鋼板の厚さ 1.2 mm
  • アームレスト調整 28-36 cm / 11.0"-14.2"
  • 床から座面トップまでの高さ 45-53 cm / 17.7"-20.9"
  • 高さの調整範囲 8 cm / 3.1"
  • リクライニング 90-180 degree
  • アームレスト 1D, 2D (Rose White)
  • ヘッドレスト Ergonomic Pillow
  • ランバーサポート Ergonomic
  • 表面素材 Perforated PU
  • インナー素材 Backrest: cut foam, Seatbase: cold molded foam
  • フレーム素材 Steel
  • 底部 (脚) Nylon
  • キャスター 60 mm / 2.4"
  • ガスシリンダ Class 4
  • 製品重量 21.5 kg / 47.4 lbs
  • 総重量 24 kg / 52.9 lbs
  • 最大負荷重 150 kg / 330 lbs
  • メーカー保証 1 year
  • 製品分類 Gaming Chair
  • チェアシリーズ Caliber R1 Series
