COSMOS C700P Black Edition image number 0
COSMOS C700P Black Edition image number 1
COSMOS C700P Black Edition image number 2
COSMOS C700P Black Edition image number 3
COSMOS C700P Black Edition image number 4
COSMOS C700P Black Edition image number 5
COSMOS C700P Black Edition image number 6
COSMOS C700P Black Edition image number 7
COSMOS C700P Black Edition image number 8
COSMOS C700P Black Edition image number 9
COSMOS C700P Black Edition image number 10
COSMOS C700P Black Edition image number 11
COSMOS C700P Black Edition image number 12
COSMOS C700P Black Edition image number 13
COSMOS C700P Black Edition image number 14
COSMOS C700P Black Edition image number 15
Raising the Bar(s)
The COSMOS C700P Black Edition extends further than its matte black coating, comprised of internal and external improvements upon the original.
Expanding the Cosmos
Upgraded Cover System
The PSU Shroud advances in modularity with two independent parts while the cable cover system features 3 separate pieces, each with the capability of mounting storage or a pump for liquid cooling.
Flat Radiator Brackets
Flat radiator brackets offer an easier maintenance, mounting, and removal process for liquid cooling with more clearance for push-pull configurations.
Our Achievements
17 Awards
Curved Tempered Glass Side Panel
A lightly-tinted tempered glass side panel with two curved edges
offer a wide view of the system build.
Rich Connectivity
Ports & Slots
Rich Connectivity
The advanced I/O panel comes with a 4-Pole headset jack (audio+mic), dedicated mic jack, USB 3.1 (Gen 2) Type-C port, four additional USB 3.0 ports, PWM fan speed button, and an addressable RGB control button.
Design
HIGHLY VERSATILE LAYOUT
The unique frame design supports a conventional, chimney, inverse
layout, or a fully customized layout. The motherboard tray is also
removable for installation outside of the chassis.
Cooling Support
16
radiator slots
Cooling Support
18
fan slots
Alternate Rear Panel
To support exotic layouts with motherboards or graphics card oriented vertically, an alternate panel with rubber grommets is included to allow a pass-through for external cables.
EXTENSIVE CABLE COVER SYSTEM
The 3 included covers can be placed on either the M. Port or on the mid-plate, with the ability to mount SSD storage or a reservoir.
仕様
  • サイズ Full Tower
  • 主材料 スチール
  • 対応水冷ラジエーター - ボトム 120mm
  • 対応水冷ラジエーター - リア 120 mm
  • 対応電源ユニット ボトムマウント
  • ダストフィルター トップ
  • 製品寸法 (L x W x H) 639 x 306 x 651mm
  • 対応ケースファン(ボトム) 2x 120/140mm*
  • 付属ケースファン - リア 1x 140mm, 1200RPM
  • 対応水冷ラジエーター - フロント 420mm (requires removal of ODD cage)
  • 付属ケースファン - フロント 2x 140mm, 1200RPM
  • Lighting Support RGB Control Board
  • ダストフィルター フロント
  • 対応水冷ラジエーター - ボトム 140mm
  • 対応水冷ラジエーター - リア 140mm
  • 対応水冷ラジエーター - フロント 360mm
  • カラー ブラック
  • 5.25"ドライブベイ 1
  • 対応水冷ラジエーター - ボトム 240mm
  • ダストフィルター ボトム
  • 対応ケースファン - リア 1x 120/140mm
  • Lighting Support 1x RGB Connection
  • 対応ケースファン - トップ 3x 120/140mm
  • 拡張スロット 8
  • 対応水冷ラジエーター - トップ 280mm
  • I/Oパネル 4x USB 3.0
  • 対応水冷ラジエーター - フロント 280mm
  • シリーズ COSMOS Series
  • 対応水冷ラジエーター - フロント 240mm
  • 対応水冷ラジエーター - トップ 240mm
  • 対応電源ユニット ATX PS2
  • 対応マザーボード E-ATX
  • 対応マザーボード ATX
  • 対応水冷ラジエーター - フロント 140mm
  • 対応水冷ラジエーター - トップ 140mm
  • 対応水冷ラジエーター - トップ 120mm
  • 対応マザーボード Micro ATX
  • 対応水冷ラジエーター - フロント 120mm
  • クリアランス - グラフィックスカード 320mm (w/ 3.5" HDD cage)
  • 2.5" / 3.5" ドライブベイ (COMBO) 4
  • 対応ケースファン - フロント 3x 120/140mm
  • 対応マザーボード Mini ITX
  • I/Oパネル 1x USB 3.1 Gen 2 Type-C
  • クリアランス - CPUクーラー 198mm
  • 対応水冷ラジエーター - トップ 360mm & 420mm (remove ODD, maximum thickness clearance 70mm)
  • I/Oパネル 3.5MMオーディオジャック x1
  • I/Oパネル 3.5MMマイクジャック x1
  • 2.5" ドライブベイ 4
  • I/Oパネル Fan Speed
  • I/Oパネル RGB Control Buttons
  • クリアランス - グラフィックスカード 490mm (w/o 3.5" HDD cage)
  • 製品重量 22.2 kg
  • 主材料 Curved Tempered Glass
  • 製品型番 MCC-C700P-KG5N-S00
