XG750 Plus Platinum Full Modular ARGB 750W PSU image number 0
XG750 Plus Platinum Full Modular ARGB 750W PSU image number 1
XG750 Plus Platinum Full Modular ARGB 750W PSU image number 2
XG750 Plus Platinum Full Modular ARGB 750W PSU image number 3
XG750 Plus Platinum Full Modular ARGB 750W PSU image number 4
XG750 Plus Platinum Full Modular ARGB 750W PSU image number 5
XG750 Plus Platinum Full Modular ARGB 750W PSU image number 6
XG750 Plus Platinum Full Modular ARGB 750W PSU image number 7
XG750 Plus Platinum Full Modular ARGB 750W PSU image number 8
Full Modular 80 PLUS Platinum ARGB Power Supply with Digital Options
The XG Plus Platinum houses Cooler Master’s first in-house designed platform.
XG750 PLUS PLATINUM
FULL MODULAR 80 PLUS PLATINUM ARGB POWER SUPPLY WITH DIGITAL OPTIONS
• Intel ATX 12V Version 2.53
• 80 PLUS Platinum Certified
• Quiet ARGB 135mm silent Fan
• Built-in Information Display Panel
• Full-Modular Cabling with 100% Japanese In-Line Capacitors
• 10-Year Warranty
Powered By Cooler Master
The XG Plus Platinum marks the culmination of many years of effort and the beginning of a new era for Cooler Master power supply units. This product line debuts the first generation of power supply platform created by Cooler Master in-house. This platform allows Cooler Master to offer an entirely new class of high efficiency products. The use of 100% Japanese capacitors allows this power supply unit to deliver top-shelf performance with reduced ripple noise.
Silence is Platinum
Some power supply units offer great cooling performance. And some offer quiet operation. The XG Plus Platinum offers both. The in-house designed was created so that we could deliver a high quality PSU that could power gaming builds at top of the line performance levels while remaining relatively cool.
  • 模組化 全模組化
  • 功率因數校正 主動式 PFC
  • 輸入頻率 50-60Hz
  • ErP 2014 Lot 3 符合
  • ATX 24 Pin 電源接頭 1
  • EPS 4+4 Pin 電源接頭 1
  • 80 PLUS 評級 80 PLUS 白金牌
  • EPS 8 Pin 電源接頭 1
  • 電源良好信號 100 - 150 ms
  • USB Protocol 10P 1
  • 平均故障間隔 (MTBF) >100,000 小時
  • 分類 500-750瓦
  • 80 Plus 白金牌認證
  • 工作溫度 0-50°C
  • SATA 電源接頭 12
  • 風扇尺寸 135mm
  • PCI-e 6+2 Pin 電源接頭 4
  • 輸入電壓 100-240V
  • 周邊 4 Pin 電源接頭 4
  • 保護機制 OVP
  • 保護機制 OPP
  • 保護機制 SCP
  • 保護機制 UVP
  • ATX 版本 Intel ATX 12V Ver. 2.53
  • 保護機制 OTP
  • 保護機制 OCP
  • 風扇轉速 1800 RPM
  • 尺寸 (長 x 寬 x 高) 160 x 150 x 86 mm
  • 保護機制 Surge and Inrush Protection
  • 安規 CCC
  • 輸入電流 10-5A
  • 安規 CE
  • 產品系列 XG 系列
  • 安規 EAC
  • 安規 cTUVus
  • 安規 FCC
  • 轉換效率 典型轉換 ≥ 92%
  • 安規 BSMI
  • 持續輸出時間 ≥ 16ms
  • 安規 TUV
  • 噪音水平 @ 100% ≤ 25 dBA
  • 安規 UKCA
  • 型號 MPG-7501-AFBAP-XTW
