X Silent Edge Platinum 850 image number 0
X Silent Edge Platinum 850 image number 1
X Silent Edge Platinum 850 image number 2
X Silent Edge Platinum 850 image number 3
X Silent Edge Platinum 850 image number 4
闃寂無聲電源
• 絕對無聲的無風扇設計
• 創新熱導管散熱技術
• 最小化電磁噪聲
• 工業級英飛凌積體電路(IC)
• 數位電源管理監控系統
• 15年保固
Precise Silent Power
Engineered with a fanless design and industrial IC components, X Silent Edge Platinum features out Heat Pipe Dissipation Patent, ensuring quietness for even the most noise-sensitive environments.
No Fan, No Dust
Equipped with a heat pipe and an innovative modular thermal structure, our design enhances thermal efficiency, essential for the low-temperature rise of key components and the ultra-quiet fanless operation.
Fully Modular Cabling
Modular cabling minimizes clutter, while the additional ports provide extra functionality.
Patented Heat Decentralized Design
Our Private Aluminum Thermal Mold effectively dissipates heat, and the Innovative Heat Pipe Thermal Tech uniformly regulates unit temperature. This ensures superior thermal control, enhancing efficiency and longevity in demanding environments.
Patented Copper-Aluminum Heat Dissipation
In-house designed composite heat pipe technology enables effective passive thermal management.
Active Bridge Rectifier Boosts Efficiency 2%
The Active Bridge Rectifier, equipped with the Infineon CoolMOS, marks a significant advancement in power efficiency. This innovative combination not only conserves electricity, but also significantly reduces power loss, outperforming traditional bridge diodes. It's an ideal solution for users seeking eco-friendly, high-efficiency power supply units.
ATX 3.1 Support & A Dual-color 12V-2X6 Cable
Includes ATX 3.1 support and a dual-color 12V-2x6 connector (with clear purple markings) help users confirm correct installation, preventing poor contact and power issues for enhanced safety and reliability.
  • 型號 MPS-8501-AZAP-NBTW
  • ATX 版本 ATX 12V Ver. 3.1
  • 功率因數校正 主動式 PFC
  • 輸入電壓 100-240V
  • 輸入電流 9-5A
  • 輸入頻率 50-60Hz
  • 尺寸 (長 x 寬 x 高) 180 x 150 x 86 mm
  • 轉換效率 典型轉換 ≥ 92%
  • 80 PLUS 評級 80 PLUS 白金牌
  • ErP 2014 Lot 3 符合
  • 工作溫度 0-40°C
  • 電源良好信號 100 - 150 ms
  • 持續輸出時間 ≥ 16ms
  • 平均故障間隔 (MTBF) >100,000 小時
  • 保護機制 OPP/ OVP/ OTP/ OCP/ SCP/ UVP/ Surge & Inrush Protection
  • 安規 cUL, TUV, CE, FCC, BSMI, CCC, EAC, RCM, UKCA/BIS, KC (based on region's request.)
  • ATX 24 Pin 電源接頭 1
  • EPS 4+4 Pin 電源接頭 1
  • EPS 8 Pin 電源接頭 1
  • SATA 電源接頭 12
  • 周邊 4 Pin 電源接頭 4
  • PCI-e 6+2 Pin 電源接頭 4
  • 12V-2x6 接頭 1
  • USB 10P 接頭 1
  • PMBus 5 Pin Connector 1
  • External Fan 4Pin Connectors 1
  • 產品系列 X 系列
  • 80 Plus 白金牌認證
  • 分類 750瓦以上
  • Watts 850W
  • 輸入電壓範圍 全電壓
