MASTERACCESSORY 通用型垂直顯卡支架套件V3 (PCIe 4.0) image number 0
MASTERACCESSORY 通用型垂直顯卡支架套件V3 (PCIe 4.0) image number 1
MASTERACCESSORY 通用型垂直顯卡支架套件V3 (PCIe 4.0) image number 2
MASTERACCESSORY 通用型垂直顯卡支架套件V3 (PCIe 4.0) image number 3
MASTERACCESSORY 通用型垂直顯卡支架套件V3 (PCIe 4.0) image number 4
MASTERACCESSORY 通用型垂直顯卡支架套件V3 (PCIe 4.0) image number 5
MASTERACCESSORY 通用型垂直顯卡支架套件V3 (PCIe 4.0) image number 6
MASTERACCESSORY 通用型垂直顯卡支架套件V3 (PCIe 4.0) image number 7
MASTERACCESSORY 通用型垂直顯卡支架套件V3 (PCIe 4.0) image number 8
MASTERACCESSORY 通用型垂直顯卡支架套件V3 (PCIe 4.0) image number 9
MASTERACCESSORY 通用型垂直顯卡支架套件V3 (PCIe 4.0) image number 10
MASTERACCESSORY 通用型垂直顯卡支架套件V3 (PCIe 4.0) image number 11
90°靈活翻轉,操縱自如
Cooler Master MasterAccessory 通用型垂直顯卡支架套件V3 (PCIe 4.0), 支援ATX 和 m-ATX
顏色
立即購買
Cooler Master Riser Cable PCIe 4.0 Included
Allows for efficient data transmission and connectivity
between the latest hardware components
Premium Materials
42%
Increased Durability
Compatibility
ATX & m-ATX Compatibility
Designed for both ATX and mATX cases, this accessory is compatible with the latest GPUs available on the market
GPU
EFFORTLESSLY SHOWCASE YOUR GRAPHICS CARD
Bring the best out of your components by showing off your GPU
Compatible with all Standard ATX Chassis
Compatibility
The newly revised Vertical Graphics Card Holder Kit fits all standard ATX chassis, now providing even more options for adjusting graphics card position.
...and all Standard M-ATX Chassis
Compatibility
Compatibility with m-ATX cases is guaranteed thanks to the brand new design that simply requires 4 PCi slots for installation.
GPU connection to external monitors is facilitated due to the modular design, now 100% adjustable according to preference and needs.
TOOLLESS, INSTANTLY ADJUSTABLE DESIGN
Adjustability
X AXIS
Adjustability
Z AXIS
Natively Compatible with "flow-through" GPU Coolers
The fully ventilated design is specially designed to allow unrestricted airflow for "flow-through" GPU coolers
  • 產品型號 Black: MCA-U000R-KFVK03, White: MCA-U000R-WFVK03
  • 顏色 Black / Gray, White / Gray
  • 尺寸 (長x寬x高) GFX Holder Kit: 249 x 148.1 x 141.8mm (close size), GFX Holder Kit: 305 x 178.1 x 141.8mm (open size), Riser Cable: 165mm (6.19in)
  • 支援機殼規格 E-ATX, ATX, Micro ATX (may interfere with component installation on the rear panel. Max. CPU cooler height limited to 70mm.)
  • 支援顯卡規格 任意長度,最多 3 個插槽寬
  • 顯卡延長線 Riser Cable PCIe 4.0 x16
  • 相容性 PCIe 4.0 及之前的版本
  • CE 證書序號 BKC210933AC
  • PCB / Wire UL E1895721 / E252840
  • 元件材料 PCBA, 銀銅線30 AWG
  • 絕緣材料 PE, TPE
  • 其他材料 ABS, PP, SGCC Steel, Nickel, Gold, Brass
  • 連接頭 PCIe x16 公頭轉 PCI PCIe x16 90° 母頭
  • 額定工作電壓和電流 DC 12V / 5A
  • 作業溫度 -20° 到 +100° (攝氏)
  • PCI slots 最少需要 4 個PCI插槽供安裝
  • 重量 0.81 kg
  • 保固 2 年
  • 系列 其他系列
