V SFX Platinum 1100 ATX 3.0 全模組SFX電源供應器 image number 0
V SFX Platinum 1100 ATX 3.0 全模組SFX電源供應器 image number 1
V SFX Platinum 1100 ATX 3.0 全模組SFX電源供應器 image number 2
V SFX Platinum 1100 ATX 3.0 全模組SFX電源供應器 image number 3
V SFX Platinum 1100 ATX 3.0 全模組SFX電源供應器 image number 4
V SFX Platinum 1100 ATX 3.0 全模組SFX電源供應器 image number 5
V SFX Platinum 1100 ATX 3.0 全模組SFX電源供應器 image number 6
V SFX Platinum 1100 ATX 3.0 全模組SFX電源供應器 image number 7
V SFX Platinum 1100 ATX 3.0 全模組SFX電源供應器 image number 8
V SFX Platinum 1100 ATX 3.0 全模組SFX電源供應器 image number 9
V SFX Platinum 1100 ATX 3.0 全模組SFX電源供應器 image number 10
V SFX Platinum 1100 ATX 3.0 全模組SFX電源供應器 image number 11
V SFX Platinum 1100 ATX 3.0 全模組SFX電源供應器 image number 12
V SFX Platinum 1100 ATX 3.0 全模組SFX電源供應器 image number 13
V SFX Platinum 1100 ATX 3.0 全模組SFX電源供應器 image number 14
業界領先SFX電源供應器
V SFX Platinum帶給您SFX規格和V系列的高品質和出色的功能,白金級轉換效率,支援ATX3.0和12VHPWR接頭(適用於40系列顯卡),相容ITX和ATX機殼,全模組線材,92mm風扇,16AWG PCIe高性能線材、100%全日系電容以及十年保固。
立即購買
AN SFX REVOLUTION
The V SFX Platinum is leading the industry as the first SFX unit to acheive 1300W, and includes top-tier features such as full compatibility with ATX 3.0 and both ITX and ATX cases, and new miniaturization technology that enhances thermal performance and increases power density.
AN SFX REVOLUTION
AN SFX REVOLUTION
MINI BUT MIGHTY
MINI BUT MIGHTY
Flat copper wiring on the DC-DC choke, flat transformer piling, an aluminum plate dissipation structure on the full-bridge LLC, and advanced manufacturing processes enhance overall miniaturization.
 ENHANCED DISSIPATION
The transformer, rectifier, full-bridge LLC, and EMI-inhibiting amorphous metal materials are fully integrated for advanced performance and heat dissipation.
ATX 3.0 support
12VHPWR CABLE
FULLY MODULAR CABLING
PSU CALCULATOR
  • 型號 MPZ-B001-SFAP-B
  • ATX 版本 SFX 12V Ver. 3.42
  • 功率因數校正 主動式 PFC
  • 輸入電壓 100-240V
  • 輸入電流 14-6.5A
  • 輸入頻率 50-60Hz
  • 尺寸 (長 x 寬 x 高) 100 x 125 x 63.5 mm
  • 風扇尺寸 92mm
  • 風扇軸承 FDB
  • 轉換效率 典型轉換 ≥ 92%
  • 80 PLUS 評級 80 PLUS 白金牌
  • ErP 2014 Lot 3 符合
  • 工作溫度 0-50°C
  • 電源良好信號 100 - 150 ms
  • 持續輸出時間 ≥16ms at 70% Load
  • 平均故障間隔 (MTBF) >100,000 小時
  • 保護機制 OPP/ OVP/ OTP/ OCP/ SCP/ UVP/ Surge & Inrush Protection
  • 安規 TUV, cTUVus, CE, BSMI, FCC, CCC, EAC, UKCA
  • ATX 24 Pin 電源接頭 1
  • EPS 4+4 Pin 電源接頭 1
  • EPS 8 Pin 電源接頭 1
  • SATA 電源接頭 8
  • 周邊 4 Pin 電源接頭 4
  • PCI-e 6+2 Pin 電源接頭 3
  • 12VHPWR 電源接頭 1
  • 80 Plus 白金牌認證
  • 產品系列 V SFX Series
  • 模組化 全模組化
  • 分類 750瓦以上
  • Form Factor SFX
  • Watts 1100W
  • ATX 版本 ATX 3.0
  • 輸入電壓範圍 全電壓
