V SFX Gold 750 ATX 3.0 Fully Modular SFX Power Supply image number 0
V SFX Gold 750 ATX 3.0 Fully Modular SFX Power Supply image number 1
V SFX Gold 750 ATX 3.0 Fully Modular SFX Power Supply image number 2
V SFX Gold 750 ATX 3.0 Fully Modular SFX Power Supply image number 3
V SFX Gold 750 ATX 3.0 Fully Modular SFX Power Supply image number 4
V SFX Gold 750 ATX 3.0 Fully Modular SFX Power Supply image number 5
V SFX Gold 750 ATX 3.0 Fully Modular SFX Power Supply image number 6
V SFX Gold 750 ATX 3.0 Fully Modular SFX Power Supply image number 7
V SFX Gold 750 ATX 3.0 Fully Modular SFX Power Supply image number 8
Small But Mighty
The V SFX Gold 750 ATX 3.0 power supply unit from Cooler Master offers fully modular cabling, 80 PLUS Gold efficiency, a highly flexible
region
ATX 3.0 Support & a Durable 90-degree 12VHPWR Cable
Flexible Compatibility
With the included SFX-to-ATX bracket, the V SFX Gold ATX 3.0 can be used to power systems ranging from as small as a mini-ITX all the way up to E-ATX motherboards.
100% Japanese Capacitors
Large, high-quality Japanese capacitors feature inmproved efficiency and reduced ripple noise.
80 PLUS Gold Certified
Fully Modular Cabling
  • 型號 MPY-7501-SFHAGV-3TW
  • ATX 版本 SFX 12V Ver. 3.42
  • 功率因數校正 主動式 PFC
  • 輸入電壓 100-240V
  • 輸入電流 10-5A
  • 輸入頻率 50-60Hz
  • 尺寸 (長 x 寬 x 高) 100 x 125 x 63.5 mm
  • 風扇尺寸 92mm
  • 風扇軸承 FDB
  • 轉換效率 典型轉換 90%
  • 80 PLUS 評級 80 PLUS 金牌
  • ErP 2014 Lot 3 符合
  • 工作溫度 0-50°C
  • 電源良好信號 100 - 500 ms
  • 持續輸出時間 16ms
  • 平均故障間隔 (MTBF) >100,000 小時
  • 保護機制 OPP/ OVP/ OTP/ OCP/ SCP/ UVP/ Surge & Inrush Protection
  • 安規 TUV, cTUVus, CE, BSMI, FCC, CCC, EAC, RCM, CB, UKCA
  • ATX 24 Pin 電源接頭 1
  • EPS 4+4 Pin 電源接頭 1
  • EPS 8 Pin 電源接頭 1
  • SATA 電源接頭 8
  • 周邊 4 Pin 電源接頭 4
  • PCI-e 6+2 Pin 電源接頭 4
  • 12VHPWR 電源接頭 1
  • 產品系列 V SFX Series
  • 80 Plus 金牌認證
  • 模組化 全模組化
  • 分類 750瓦以上
  • Form Factor SFX
  • Watts 750W
  • ATX 版本 ATX 3.0
