V Platinum 1300 V2 | A quietly supreme PSU image number 0
V Platinum 1300 V2 | A quietly supreme PSU image number 1
V Platinum 1300 V2 | A quietly supreme PSU image number 2
V Platinum 1300 V2 | A quietly supreme PSU image number 3
V Platinum 1300 V2 | A quietly supreme PSU image number 4
V Platinum 1300 V2 | A quietly supreme PSU image number 5
V Platinum 1300 V2 | A quietly supreme PSU image number 6
V Platinum 1300 V2 | A quietly supreme PSU image number 7
V Platinum 1300 V2 | A quietly supreme PSU image number 8
V Platinum 1300 V2 | A quietly supreme PSU image number 9
V Platinum 1300 V2 | A quietly supreme PSU image number 10
V Platinum 1300 V2 | A quietly supreme PSU image number 11
QUIETLY SUPREME
Introducing the V Platinum V2, featuring an ultra-quiet Mobius fan, 80 Plus Platinum efficiency, and ATX 3.1 support with a durable 12V-2x6 cable.
QUIETLY SUPREME
V Platinum V2 delivers silent operation, featuring an ultra-quiet Mobius fan, a protective conformal coating heatsink, smart thermal control, zero-RPM fan mode, fully modular cabling, and 80 Plus Platinum efficiency, backed by a 12-year warranty.
QUIETLY SUPREME
QUIETLY SUPREME
MOBIUS FAN ENHANCES THERMAL PERFORMANCE AND A LONGER LIFESPAN
An ultra-quiet Mobius fan featuring high-performance oil reflow, an innovative ring blade design, and accelerated pressure air vents provides improved noise levels and advanced thermal performance.
OIL FLOWS BACK TO THE SEALED BEARING, ENSURING CONSTANT LUBRICATION.
A loop dynamic bearing with a thick oil coating ensures stable performance, prolongs the fan's lifespan, and effectively reduces noise.
SILENT FAN PERFORMANCE WITH A ZERO SPEED MODE
A quieter, speedier fan features lower noise level output and improved airflow thanks to a higher RPM.
ADVANCED HEAT DISSIPATION
Purple anodic-coated heat sink with bevel cut lowers average temperatures, compared to traditional heat sinks. Bevel cuts bring out the heat source more effectively, and after concentrating the flow field, benefiting the heat dissipation.
CERTIFIED EFFICIENCY
An interleaved PFC decreases power loss and improves efficiency by inimizing current, reducing interference, and reducing output capacitor ripple current.
Durable Cable
FULLY MODULAR CABLING
A modular cable management design reduces clutter, increases airflow, and improves overall efficiency as well as thermal performance.
  • 型號 MPZ-D002-AFAP-BTW
  • ATX 版本 ATX 12V Ver. 3.1
  • 功率因數校正 主動式 PFC
  • 輸入電壓 100-240V
  • 輸入電流 15-7A
  • 輸入頻率 50-60Hz
  • 尺寸 (長 x 寬 x 高) 160 x 150 x 86 mm
  • 風扇尺寸 135mm
  • 風扇軸承 LDB
  • 風扇轉速 2400±10% RPM
  • 轉換效率 典型轉換 ≥ 92%
  • 80 PLUS 評級 80 PLUS 白金牌
  • ErP 2014 Lot 3 符合
  • 工作溫度 0-50°C
  • 電源良好信號 100 - 150 ms
  • 持續輸出時間 ≥ 16ms
  • 平均故障間隔 (MTBF) >100,000 小時
  • 保護機制 OPP/ OVP/ OTP/ OCP/ SCP/ UVP/ Surge & Inrush Protection
  • 安規 cTUVus, TUV, CE, FCC, BSMI, CCC, EAC, RCM, UKCA, RoHS2.0 / BIS, KC (Based on region's requests.)
  • ATX 24 Pin 電源接頭 1
  • EPS 4+4 Pin 電源接頭 1
  • EPS 8 Pin 電源接頭 1
  • SATA 電源接頭 16
  • 周邊 4 Pin 電源接頭 4
  • PCI-e 6+2 Pin 電源接頭 5
  • 12V-2x6 接頭 1
  • 產品系列 V Platinum 系列
  • 80 Plus 白金牌認證
  • 模組化 全模組化
  • 分類 750瓦以上
  • Watts 1300W
