Thermal Pad 導熱片 image number 0
Thermal Pad 導熱片 image number 1
Thermal Pad 導熱片 image number 2
Thermal Pad 導熱片 image number 3
Thermal Pad 導熱片 image number 4
Thermal Pad 導熱片
Thermal Pad 導熱片
Thermal Pad 導熱片
Thermal Pad 導熱片
Thermal Pad 導熱片
多樣酷冷新選擇
Thermal Pad 導熱片
Cooler Master新的導熱片Thermal Pad 產品為一創新的產品。設計給您搭配所有您可能使用到的電子裝置。
FORMULATED WITH NANO ELEMENTS
13.3w/mK thermal conductivity for rapid cooling, capable of drawing high levels of heat.
NON-TOXIC AND NON-CORROSIVE
Safe and simple formula with electrically insulated and heat resistant properties to prevent hardening.
DOUBLE-SIDED ADHESIVE
Provides seamless and secure contact between surfaces.
WIDE RANGE OF APPLICATION
Electronic devices, motherboards, components (CPU, GPU, USICS, Hard Drives, Disk Drives, IGBT module), laptops and various products requiring cooling.
VERSATILE AND EASY APPLICATION
  • 產品型號 TPX-NOPP-9005-R1, TPX-NOPP-9010-R1, TPX-NOPP-9015-R1, TPX-NOPP-9020-R1, TPX-NOPP-9030-R1
  • 尺寸 (長 x 寬 x 高) 95 x 45 mm
  • 導熱係數 13.3 (W/m.K)
  • 顏色 紫色
  • 密度 3.4 ± 0.2 g/cc
  • 硬度 30~60 Sc
  • 絕緣崩潰電壓 6KV (1mm)
  • 工作溫度 -40 ~ 200°C
  • 產品類型 散熱膏
