Thermal Pad Pro 導熱片 image number 0
多樣酷冷新選擇
Thermal Pad Pro 導熱片
Cooler Master新的導熱片Thermal Pad Pro產品為一創新的產品。設計給您搭配所有您可能使用到的電子裝置。
THERMAL PAD PRO
COOLING VERSATILITY EVERYWHERE
THERMAL PAD PRO
Formulated with Nano Diamond Particles
Non-toxic and Non-corrosive
Double-sided Adhesive
Versatile and Easy Application.
Cooler Master's new Thermal Pad Pro is an innovative solution to device cooling for a vast range of your electronic devices and components.
FORMULATED WITH NANO DIAMOND PARTICLES
15.3w/mK thermal conductivity for rapid cooling, capable of drawing high levels of heat.
NON-TOXIC
AND NON-CORROSIVE
Safe and simple formula with electrically insulated and heat resistant properties to prevent hardening.
DOUBLE-SIDED ADHESIVE
Provides seamless and secure contact between surfaces.
VERSATILE AND EASY APPLICATION
Easily cut to the perfect size for your application. Choices of 1mm and 2mm thickness are available.
WIDE RANGE OF APPLICATION
Electronic devices, motherboards, components (CPU, GPU, USICS, Hard Drives, Disk Drives, IGBT module), laptops and various products requiring cooling.
  • 產品型號 TPY-NDPB-9010-R1, TPY-NDPB-9020-R1
  • 尺寸 (長 x 寬 x 高) 95 x 45 mm
  • 導熱係數 15.3 (W/m.K)
  • 顏色 藍色
  • 密度 3.4 ± 0.2 g/cc
  • 硬度 30~55 Sc
  • 絕緣崩潰電壓 6KV (1mm)
  • 工作溫度 -40 ~ 200°C
  • 產品類型 散熱膏
