DEEP BLACK PERFORMANCE
Thanks to MiniLED technology, local dimming zones are even smaller and more granular than ever before. With local dimming activated you can obtain extraordinary HDR performance with a contrast ratio of 50,000:1.
提供卓越的視覺效果
TEMPEST GP27U適用於每個客群,通過 Mini LED UHD 和160Hz刷新率,增強您的工作/娛樂體驗。
Using a quantum-dot enhancement film, colors are more vibrant and can emit an even more precise amount of light, leading to stronger color reproduction and wider color gamut, making it perfect for color accurate work.
Reach a new level of clarity for everything you watch. MiniLED's improved display technology brightens whites and darkens blacks for an HDR picture that has an unprecedented level of picture quality. The Tempest GP27U can reach 600 nits of peak brightness in SDR mode, or 1200 nits in HDR mode. This is how MiniLED shows all your favorite content in a whole new light.
Tempest GP27U uses the latest Ultra-Speed IPS panels which is up to 4x faster than traditional IPS panels. Combined with carefully tuned overdrive profiles, the pixels transition faster to other colors and scenes, while minimizing overshoot for exceptionally smooth picture quality with significantly less motion blur or smearing. Not satisfied with any of the overdrive presets? For the first time, you can completely customize the overdrive level of your monitor within the OSD menu from values 0 to 100 for an even more fine-tuned experience.
Protect your eyes from potentially harmful blue light with our Low Blue Light Mode. The Tempest MiniLED series are also flicker-free*, further reducing any eye strain and allowing you to get more work or gaming done.
*flicker-free is only when local dimming is not enabled.
With two full-bandwidth HDMI 2.1 ports, equivalent to 48Gbps, the Tempest GP27U completely supports consoles like the Xbox Series X and PS5 at 4K resolution, 120Hz refresh rate without the need for any Display Stream Compression (DSC), making it a future-proof monitor for years to come.
KVM SWITCHER INTEGRATION
With a built-in KVM switch in the Tempest Monitor series, you can easily control an extra device such as a laptop, another desktop, tablet, or a phone using only a single set of a keyboard and mouse. With a simple toggle in the OSD menu, you can seamlessly swap controls to your second device for ultimate multitasking.
最多可自訂 5 組不同的色彩設定檔,以因應各種使用情境。在 FPS 遊戲中,您可能會想提高黑階穩定化,以便在黑暗中更清楚地看見敵人;而在 RPG 遊戲或電影中,您可能偏好讓黑色維持更暗的效果,以提升沉浸感。選擇權在您手上,您可以針對可能遇到的各種情境,量身打造 5 組不同的設定檔。
With a wide range of adjustability, the Tempest GP27U can be positioned to the way you want it exactly.
With the Halo ring as the base of the stand, the Tempest GP27U features a design that is not only sleek, but also with a hint of flair. For those who want a clean aesthetic with minimal branding. the Tempest MiniLED series monitors are the perfect addition to your setup.
• 1 x DisplayPort
• 2 x HDMI 2.1
• 2 x USB Type A
• 1 x USB Type C (supports 90W PD charging output)
• 1 x 3.5mm Headphone Jack
