憑藉 MiniLED 技術,區域調光分區比以往更小、更細緻。啟用區域調光後,您可獲得對比度高達 50,000:1 的非凡 HDR 表現。
提供卓越的視覺效果
TEMPEST GP27Q適用於每個客群,通過 Mini LED UHD 和165Hz刷新率,增強您的工作/娛樂體驗。
With specifications perfect for both the working professional as well as the hardcore gamer, the Tempest GP27Q is a true do-it-all monitor. Equipped with a 2560 x 1440 resolution panel that covers 98% of the DCI-P3 color spectrum, and boasts 165Hz refresh rate with a 1 ms response time, this monitor can be the perfect centerpiece to your work and play setup.
With a wide range of adjustability, the Tempest GP27Q can be positioned to the way you want it exactly.
2 x USB Type A
1 x Type B
2 x HDMI 2.0
1 x DisplayPort
1 x USB Type C (supports 90W PD charging output)
1 x 3.5mm Headphone Jack
