最佳化散熱設計
GP2711 採用 Cooler Master 獨特的散熱片與背蓋散熱設計,無需風扇即可提升散熱效能。此設計可將主晶片溫度降低約 5°C,並將產品耐用度延長 30%。無論是長時間工作或娛樂,都能享受無與倫比的溫度穩定性。此外,還享有我們的 4 年保固。
一同潛入遊戲世界
Tempest GP2711專為狂熱的遊戲玩家和要求嚴格的創作專業人士設計。採用Cooler Master獨家創新技術,獨特的散熱設計提升30%的使用壽命。搭載Mini LED、QHD解析度、量子點技術和165Hz的刷新率且擁有廣泛的130% sRGB和95% DCI-P3色域,提升遊戲和創作體驗。
Our VA panel, with the latest Mini-LED technology, provides an ultra-high contrast visual experience in HDR. In HDR+ local dimming mode, it can achieve over 3,000,000:1 contrast*.
* Based on LAB testing
While standard Mini-LED monitors suffer from low contrast and pronounced halo effects, the GP2711 offers high contrast with minimal halo problems.
Using a quantum dot enhancement film, the GP2711 offers brighter, more vibrant colors with exceptional color reproduction, covering 93.5% of the Adobe RGB and 95% of the DCI-P3 color gamut ranges.
The QHD resolution not only offers sharper visuals, but also provides more screen space, making multitasking a breeze and gaming more immersive.
GP2711 採用高速 165Hz 面板,搭配反應極快的 1ms (MPRT) / 低於 4ms GtG 反應時間,並經過精心校準以達到最佳的 Overdrive 效能。
FreeSync ensures smooth, lifelike gameplay that accurately reproduces a level of realism to everything you play. By synchronizing the frames outputted from the GPU to the refresh rate of the monitor, you can experience tear-free gameplay that is smoother than ever.
Our monitors are hand-calibrated at the factory, promising impeccable color reproduction with a delta E ≤ 2*. Witness content as the creator envisioned.
* sRGB mode
With TUV Certificate hardware-enabled Low Blue Light Mode and Flicker-Free technology, the GP2711 is gentle on the eyes, minimizing fatigue as you get more work or gaming done.
Connect your devices with I/O ports consisting of:
• HDMI 2.0 x 2
• DP 1.4 x 1
• Type-C x 1 (DP Alt Mode & PD15W)
• USB Type-B 3.0 x 1
• USB Type-A 3.0 x 2
• 3.5 mm Audio Out x 1
• Speaker 2W x 2
