Tempered Glass Side Panel image number 0
Tempered Glass Side Panel for MasterCase5, 6, MC500, MC600, H500P and H500M
Overview
The tempered glass side panel bring a premium touch to your chassis and allow to highlight any system from water cooling advanced build up to the simpliest configuration.
The quality of the glass guarantee a long life durability and the bracket design hold the side panel to prevent any falls.
Compatible with:
• MasterCase 5 Series
• MasterCase 6 Series
• MC500 Series
• MC600 Series
• H500P & H500M
Overview
Overview
  • 每包數量 每包1件
  • 產品型號 MCA-M500R-TGSP00-DBT (Dark Black Tinted)
  • 產品型號 MCA-M500R-TGSP00-LGT (Light Grey Tinted)
  • 顏色 深黑或淺灰色
  • 材質 - 左側板 Tempered Glass, Steel, Plastic
  • 尺寸 (長x寬x高) 460 x 460 x 23 mm / 18.1 x 18.1 x 0.9 inch
  • 淨重 2.2 Kg / 4.9 lb
  • 總重量 3.1 Kg / 6.8 lb
  • 保固 1 年
  • 系列 其他系列
  • Legacy Accessories
  • 配件 側板
