Silencio S600 image number 0
Silencio S600 image number 1
Silencio S600 image number 2
Silencio S600 image number 3
Silencio S600 image number 4
Silencio S600 image number 5
Silencio S600 image number 6
Silencio S600 image number 7
Silencio S600 image number 8
Silencio S600 image number 9
Silencio S600 image number 10
Silencio S600 image number 11
Silencio S600 image number 12
Silencio S600 image number 13
Silencio S600 image number 14
Silencio S600 image number 15
Silencio S600 image number 16
Silencio S600 image number 17
Silencio S600 image number 18
Silencio S600 image number 19
Silencio S600 image number 20
Silencio S600 image number 21
Silencio S600
Silencio S600
Silencio S600
Silencio S600
Silencio S600
Silencio S600
Silencio S600
Silencio S600
Silencio S600
Silencio S600
Silencio S600
Silencio S600
Silencio S600
Silencio S600
Silencio S600
Silencio S600
Silencio S600
Silencio S600
Silencio S600
Silencio S600
Silencio S600
Silencio S600
靜音系列作
Silencio S600
Silencio 是一款不用向散熱效能妥協的靜音機殼。主機由隔音材料環繞,所有風扇都配有橡膠緩衝墊,上方面板可拆卸的遮罩能夠阻隔噪音。Silencio S600 也同時提供強化玻璃或是帶有隔音材料的金屬側板型號供選擇。對於效能有所要求的平台,可移除上方面板的隔音遮罩增加通風。
立即購買
Silencio Technology
Sound Dampening Material
Top
Ventilation
For an even higher demand for ventilation, the top panel’s Sound Dampening Cover can be removed for unrestricted ventilation. An optional dust filter for the top panel ventilation is included, allowing the top panel and front panel to work in conjunction to cool the system.
Ventilation
Reversible Steel Door
Silencio Fans
Silencio Fans
Motherboard Support
Mini-ITX, Micro-ATX, ATX
Cooling Support
Fan
Radiators
Top:
120 / 140mm x 2 Fans
120 / 240mm* Radiator
*remove ODD cage
35mm max motherboard component height
Front:
120 / 140 / 240 / 280 Radiator
Rear:
120 x 1 Fan
120 x 1 Radiator
Storage Support
5.25” ODD x 1 (ODD version)
3.5” HDD x 4
2.5” SSD x 5
Clearances
CPU Cooler (Steel): 167mm
CPU Cooler (TG): 166mm
Power Supply: 180mm
Graphics Card: 398mm
  • 產品型號 MCS-S600-KN5N-S00 (Steel), MCS-S600-KG5N-S00 (TG)
  • 顏色 黑
  • 材質 - 機身 Steel, Plastic, Sound Absorbing Material
  • 材質 - 側板 Steel: Sound-Dampened Steel, TG: Left: Tempered Glass, Right: Sound-Dampened Steel
  • 尺寸 (長x寬x高) 478 x 209 x 470.5mm (Incl. Protrusions), 466 x 209 x 460.5mm (Excl. Protrusions)
  • 容量 44.8L (Excl. Protrusions)
  • 主機板支援 Mini-ITX, Micro-ATX, ATX
  • PCI 擴充槽 7
  • 5.25" 硬碟架 1
  • 3.5" 硬碟架 4
  • 2.5" 硬碟架 5
  • I/O 面板 - USB 埠 2x USB 3.2 Gen 1 (formerly USB 3.0)
  • I/O 面板 - 音效輸入/輸出 3.5mm 耳麥複合插孔(音訊 + 麥克風)* 1
  • I/O Panel - SD Card Reader Supports SD & MMC Cards
  • 預裝風扇 - 前方 1x 120mm (PWM 800-1400 RPM)
  • 預裝風扇 - 後方 1x 120mm (PWM 800-1400 RPM)
  • 風扇支援 - 前方 2x 120/140mm
  • 風扇支援 - 上方 2x 120/140mm
  • 風扇支援 - 後方 1x 120mm
  • 水冷支援 - 前方 120 / 140 / 240 / 280mm
  • 水冷支援 - 上方 120mm / 240mm (移除光碟機) (主機板元件高度上限35mm)
  • 水冷支援 - 後方 120mm
  • 預留安裝空間 - CPU 散熱器 Steel: 167mm, TG: 166mm
  • 預留安裝空間 - 電源供應器 180mm
  • 預留安裝空間 - 顯示卡 398mm
  • 整線空間 18-26mm
  • 防塵濾網 前方、上方、底部
  • 電源供應器類型 Bottom Mount, ATX PS2
  • 尺寸 中直立式
  • 系列 Silencio 系列
