Silencio S400 White image number 0
Silencio S400 White image number 1
Silencio S400 White image number 2
Silencio S400 White image number 3
Silencio S400 White image number 4
Silencio S400 White image number 5
Silencio S400 White image number 6
Silencio S400 White image number 7
Silencio S400 White image number 8
Silencio S400 White
Silencio S400 White
Silencio S400 White
Silencio S400 White
Silencio S400 White
Silencio S400 White
Silencio S400 White
Silencio S400 White
Silencio S400 White
靜音系列作 白色新登場
Silencio S400 White
Silencio 是一款不用向散熱效能妥協的靜音機殼。主機由隔音材料環繞,所有風扇都配有橡膠緩衝墊,上方面板可拆卸的遮罩能夠阻隔噪音。Silencio S400 也同時提供強化玻璃或是帶有隔音材料的金屬側板型號供選擇。對於效能有所要求的平台,可移除上方面板的隔音遮罩增加通風。
Silencio Design
Silencio Design
The Silencio’s minimalistic design cloaks its complexity. Design elements fine-tuned in form and function result in minimized noise and efficiently maintained system temperatures.
Silencio Technology
Silencio Technology
Behind the outer panels are pieces of meticulously placed sound dampening material. The development of the Silencio was driven by Sorama’s Cam64—this allowed for the entire sound spectrum to be visually analyzed by source, resonance pattern, and frequency.
With the identification of peaks within certain frequency ranges, fine-tuning the Silencio for the dispersion of resonance was made possible, reducing the prominence of noise generated by system components. Every detail in design optimized the Silencio for thermal efficiency and silence, from the type of material used to its placement.
Sound Dampening Material
Seamless Tempered Glass or Sound-dampened Steel
Available with seamless tempered glass or a sounddampened steel side panel, systems can be built for show or for stealth with the Silencio.
Top Panel Options
Reversible Steel Door & ODD Support
(re)movable Drive Cage
Motherboard Support
Motherboard Support
Mini-itx, Micro-atx
Cooling Support
Cooling Support
Top:
120 / 140mm x 1 Fans
120 / 140mm x 2* Fans
120 / 240mm* Radiator
*remove ODD cage
Front:
120 / 140mm x 2 Fans
120 / 140 / 240 / 280mm* Radiator
*may interfere with HDD mounted below ODD bracket
Rear:
120 x 1 Fan
120 x 1 Radiator
Storage Support
Storage Support
5.25inch ODD x 1
3.5inch HDD x 4
2.5inch SSD x 4
  • 產品型號 金屬側板: MCS-S400-KN5N-SJP, 強化玻璃透側: MCS-S400-KG5N-SJP
  • 外觀顏色
  • 材質 - 機身 Steel, Plastic, Sound Absorbing Material
  • 材質 - 左側板 隔音材料 金屬 (MCS-S400-KN5N-SJP), 強化玻璃 (MCS-S400-KG5N-SJP)
  • 尺寸 (長x寬x高) 418 x 210 x 408mm (包含突起), 403.5 x 210 x 400mm (不含突起)
  • 容量 33.9L (不含突起)
  • 主機板支援 Mini-ITX, Micro-ATX
  • PCI 擴充槽 4
  • 5.25" 硬碟架 1
  • 3.5" 硬碟架 4
  • 2.5" 硬碟架 4
  • I/O 面板 - USB 埠 1x USB 3.0, 1x USB 3.1 Type C
  • I/O 面板 - 音效輸入/輸出 3.5mm 耳麥複合插孔(音訊 + 麥克風)* 1
  • I/O Panel - SD Card Reader Supports SD & MMC Cards
  • 預裝風扇 - 前方 1x CF120 無LED燈 (白色版)
  • 預裝風扇 - 後方 1x CF120 無LED燈 (白色版)
  • 風扇支援 - 前方 2x 120/140mm
  • 風扇支援 - 上方 1x 120mm, 1x 140mm / 2x 120mm, 2x 140mm (remove ODD cage)
  • 風扇支援 - 後方 1x 120mm
  • 水冷支援 - 前方 120 / 140 / 240 / 280mm (remove & reinstall ODD bracket to mount 280mm radiator, may interfere with HDD mounted below ODD bracket)
  • 水冷支援 - 上方 120mm, 240mm* (*240mm requires removal of ODD cage)
  • 水冷支援 - 後方 120mm
  • 預留安裝空間 - CPU 散熱器 Steel: 167mm, TG: 166mm
  • 預留安裝空間 - 電源供應器 325mm (w/o front radiator & drive cage), 140mm (HDD cage in backmost position)
  • 預留安裝空間 - 顯示卡 319mm
  • 整線空間 20mm
  • 防塵濾網 前方、上方、底部
  • 電源供應器類型 Bottom Mount, ATX PS2
  • 尺寸 迷你直立式
  • 系列 Silencio 系列
