SickleFlow Edge 120 ARGB 3-pack Fan Kit White Edition image number 0
Same Legend, More Edge
  • Enhanced Fan Blade
  • Redesigned Fan Frame
  • Improved bearing system
  • A1 Mini LED Controller
SAME LEGEND, MORE EDGE
The SickleFlow Edge 120 ARGB 3-Pack Fan Kit features an enhanced fan blade, a newly redesigned frame, a novel bearing system, and an ARGB gen 2 mini controller for maximal performance and triple the power.
Enhanced Fan Blade
An improved fan blade provides higher fan speed, air pressure, and airflow while sticking to the same low noise level the SickleFlow is known for.
REDESIGNED FAN FRAME
The SickleFlow’s signature lines are now included in the frame design to provide a more cohesive product design.
IMPROVED BEARING SYSTEM
An enhanced loop dynamic bearing system keeps things running silently smooth.
A1 MINI LED CONTROLLER
Control and customize your SickleFlow Edge 120 Fan Kit's lighting with a compact, easy-to-use mini controller.
  • 產品型號 MFX-B2DW-253P2-R2
  • 外觀顏色 白色
  • 設定檔 Addressable Gen 2 RGB
  • 風扇轉速 690-2500 RPM ± 10%
  • 風扇風量 70.7 CFM
  • 風扇噪音水平 32.8 dBA
  • 風扇壓力 3.61 mmH₂O
  • 風扇平均故障間隔 >160,000 小時
  • 風扇連接介面 4-Pin (PWM)
  • 風扇額定電壓 12 VDC
  • 風扇額定電流 0.2A
  • 風扇安全電流 0.3A
  • 風扇功耗 2.4W
  • RGB 連接介面 3-Pin ARGB
  • RGB 額定電壓 5 VDC
  • RGB 額定電流 0.21A
  • 風扇重量 168g / 0.37 lbs
  • 產品保固 2年
