SickleFlow 80 8公分PWM風扇 image number 0
SickleFlow 80 8公分PWM風扇 image number 1
SickleFlow 80 8公分PWM風扇 image number 2
SickleFlow 80 8公分PWM風扇 image number 3
SickleFlow 80 8公分PWM風扇 image number 4
經典進化 全面之選
延續SickleFlow系列,酷碼推出全新升級的的SickleFlow 80風扇系列,為玩家帶來更強的散熱效能。針對扇葉曲面有了進一步優化,大幅提升風量、風壓的效能表現。強化的風扇框架有效降低擾流以及噪音的產生,並增加整體工作效率。風扇軸承採用全包覆設計,更可以保證風扇的運作的穩定性以及使用壽命。
立即購買
OPTIMIZED FLOW AND PRESSURE
Continuing the SickleFlow 120 series , Cooler Master introduces a new models with brand new upgraded design features for enhanced performance.
The new SickleFlow 80 fan blades are created with bigger blades and increased curvature to optimize the air flow and air pressure performance. Strengthen structural frame design with added rib housing for durability. Improved dustproof and oil leakage prevention for beater life expectancy,
Improved Frame Durability
Enhanced square frame structure with added rib-support for reducing turbulent flow, noise and increasing overall work efficiency.​
New Air Balance Blade
Optimized fan blade design with increased curvature that improves air flow and air pressure.​
New Bearing Sealant
Two-tier sealing mechanism designed to improve dustproof capabilities and prevent lubricant oil leakage for extended life span and performance.
  • 產品型號 MFX-B8NN-25NPK-R1
  • 風扇設定檔 無 LED
  • 風扇軸承類型 來福軸承 (Rifle Bearing)
  • 風扇轉速 650-2500 RPM ± 5%
  • 風扇風量 30 CFM
  • 風扇風壓 2.75 mmH2O
  • 風扇噪音水平 6 - 25 dBA
  • 風扇尺寸 (長 x 寬 x 高) 80 x 80 x 25 mm / 3.1 x 3.1 x 1.0 inch
  • 風扇平均故障間隔 160,000 小時
  • 風扇額定電壓 12 VDC
  • 風扇額定電流 0.11A
  • 風扇安全電流 0.18A
  • 風扇功耗 1.32W
  • 風扇連接介面 4-Pin (PWM)
  • 風扇重量 83g / 0.18 lbs
  • 產品保固 2年
  • 產品類型 機殼風扇
  • 系列 SickleFlow
  • 風扇尺寸 80
  • 風扇LED種類 Non-LED
