QUBE 500 低調黑&極致白 image number 0
QUBE 500 低調黑&極致白 image number 1
QUBE 500 低調黑&極致白 image number 2
QUBE 500 低調黑&極致白 image number 3
QUBE 500 低調黑&極致白 image number 4
QUBE 500 低調黑&極致白 image number 5
QUBE 500 低調黑&極致白 image number 6
QUBE 500 低調黑&極致白 image number 7
QUBE 500 低調黑&極致白 image number 8
QUBE 500 低調黑&極致白 image number 9
QUBE 500 低調黑&極致白 image number 10
QUBE 500 低調黑&極致白 image number 11
QUBE 500 低調黑&極致白 image number 12
QUBE 500 低調黑&極致白 image number 13
QUBE 500 低調黑&極致白 image number 14
QUBE 500 低調黑&極致白 image number 15
QUBE 500 低調黑&極致白 image number 16
QUBE 500 低調黑&極致白
QUBE 500 低調黑&極致白
QUBE 500 低調黑&極致白
QUBE 500 低調黑&極致白
QUBE 500 低調黑&極致白
QUBE 500 低調黑&極致白
QUBE 500 低調黑&極致白
QUBE 500 低調黑&極致白
QUBE 500 低調黑&極致白
QUBE 500 低調黑&極致白
QUBE 500 低調黑&極致白
QUBE 500 低調黑&極致白
QUBE 500 低調黑&極致白
QUBE 500 低調黑&極致白
QUBE 500 低調黑&極致白
QUBE 500 低調黑&極致白
QUBE 500 低調黑&極致白
自由打造自己的風格
QUBE 500 低調黑&極致白
全新個性化機殼,發揮想像力,打造出自己的風格。
顏色
立即購買
Fully Modular
Features modular panels that simplify and streamline the usual case
prep process. Every panel is separately removable for easy maintenance.
Flatpack Assembly
Besides the clear eco-benefits, we believe flat-packing will provide a fun and satisfying build experience.
Welcome to the future of PC DIY.
Swappable Side Panels
The symmetric design allows you to switch the steel panel and the glass panel with each other for a non-transparent build.
Highly Customizable
An unprecedented level of customizability allows for full creative expression.
Mult-color Macaron edition
Color your way
Fully express yourself with the multi-color Macaron edition. It includes two sets of extra panels, an extra handlebar, and two accessory hooks (only available on Macaron edition models). Mix and match the modular panels to create a case that is truly your own.
Side radiator bracket
Extra Airflow
The side radiator mount has two positions, allowing you to install a 280mm radiator or provide your GPU with extra airflow.
GPU Bracket
Built-in vertical
Vertically mount your GPU with the included bracket. You can even adjust the distance from the side panel to maintain good airflow.
Accessory ecosystem
The Qube 500 comes with a living accessory ecosystem. A Gem mini cable manager and accessory hook are included (only available on Macaron edition models), and we have prepared some 3D-printable files for you to create your own accessories.
  • 產品型號 QUBE 500 Flatpack: Q500-KGNN-S00, QUBE 500 Flatpack White: Q500-WGNN-S00
  • ��觀顏色 黑色, 白色
  • 材質 - 外部 Steel, Plastic, TG
  • 材質 - 左側板 灰色鋼化玻璃 + 鋼材
  • 尺寸 (長x寬x高) 406 x 231 x 415mm (Incl. Protrusions), 380 x 231 x 381mm (excl. Protrusions)
  • 容量 33.44L (不包含突出部分)
  • 主機板支援 ITX / Micro ATX / ATX / E-ATX (Width up to 296mm w/ SFX PSU, up to 273 w/ ATX PSU)
  • PCI 擴充槽 7
  • 3.5" 硬碟架 4
  • 2.5" 硬碟架 3
  • I/O 面板 - USB 埠 USB 3.2 Gen 1 Type A * 2, USB 3.2 Gen 2x2 Type C * 1
  • I/O 面板 - 音效輸入/輸出 1x 3.5mm Combo
  • 預裝風扇 - 後方 QUBE 500 Flatpack: 1x 120mm (1800 RPM) SF Black PWM, QUBE 500 Flatpack White: 1x 120mm (1800 RPM) SF White PWM
  • 風扇支援 - 前方 1x 120/140mm (x2: 電供於底部)
  • 風扇支援 - 上方 2x 120/140mm
  • 風扇支援 - 後方 1x 120mm
  • 風扇支援 - 底部 2x 120/140mm
  • 風扇支援 - 左側 2x 120/140mm
  • 水冷支援 - 前方 120/140 mm (240/280mm w/ PSU in bottom)
  • 水冷支援 - 上方 120 / 140 / 240 / 280mm (280mm can be used within 53mm thickness)
  • 水冷支援 - 後方 120mm
  • 水冷支援 - 底部 120 / 140 / 240 / 280mm
  • 水冷支援 - 左側 120 / 140 / 240 / 280mm
  • 預留安裝空間 - CPU 散熱器 164mm-172mm (未裝水冷支架)
  • 預留安裝空間 - 電源供應器 173mm to first GPU slot, 216 maximum space (w/o cable management space), 332mm space mounted in bottom (w/o cable management space)
  • 預留安裝空間 - 顯示卡 365mm
  • 電纜佈線 - 主板托盤後面 29-32mm
  • 手把 QUBE 500 Flatpack: Black x 1, QUBE 500 Flatpack White: Grey x 1
  • Gem Mini QUBE 500 Flatpack: Black x 1, QUBE 500 Flatpack White: Grey x 1
  • 防塵濾網 Front, Top, Bottom, Right side
  • 電源供應器類型 SFX / SFX-L / ATX
  • 保固 2 年
  • 尺寸 中直立式
  • 系列 QUBE 系列
  • 備註 -
