PL240 SPR Edition CPU Liquid Cooler image number 0
PL240 SPR Edition CPU Liquid Cooler image number 1
PL240 SPR Edition CPU Liquid Cooler image number 2
PL240 SPR Edition CPU Liquid Cooler image number 3
PL240 SPR Edition CPU Liquid Cooler image number 4
Introducing the PL240 SPR Edition, our new cooling workhorse designed to power through the toughest tasks you will tackle in your day to day
 Certified by INTEL
Certified by INTEL
Introducing Cooler Master’s PL240/360 SPR Edition, our new cooling workhorse designed to power through the toughest tasks you will tackle in your day to day, in tandem with Intel’s latest Xeon Platinum Processor. The PL240/360 hhas been designed specifically for the Xeon and is Intel-certified to be exclusively compatible with its LGA 4677 sockets. Power up your workstation with the ultimate cooler-processor duo.
Learn More
 Large, full-coverage Copper Base
An extra-large copper base ensures rapid heat transfer while a double impeller brings more powerful water flow for quick heat dissipation to ensure your workflow is never interrupted.
 Industrial-grade Structural Design
Industrial-grade structural design provides a fully sealed chamber and totally stable operation, for whisper quiet operation that won’t distract or derail your productivity.
 Double Impeller
Double Impeller
A double impeller strengthens water flow, again reinforcing heat dissipation for that extra cooling oomph when you’re pushing your machine to the limits with multiple applications and complex tasks.
CPU COMPATIBILITY
CPU COMPATIBILITY
Learn More
  • 產品型號 MLO-D24M-A24PK-R1
  • 外觀顏色 黑色
  • CPU 腳位 LGA4677
  • 水冷頭尺寸 118 x 78 x 24.7 mm
  • 水冷排材質
  • 水冷排尺寸 277 x 119.6 x 27.2 mm
  • 幫浦使用壽命 >198,000 小時
  • 幫浦噪音等級 25 dBA (最大)
  • 幫浦連接器 4-Pin
  • 幫浦額定電壓 12 VDC
  • 幫浦功耗 7W
  • 風扇數量 2 個
  • 風扇 LED 類型 Non-LED
  • 風扇轉速 0-2050 RPM ± 10%
  • 風扇風量 63.1 CFM (最大)
  • 風扇噪音水平 22.6 dBA (最大)
  • 風扇壓力 2.69 mmH₂O (最大)
  • 風扇軸承類型 循環動態軸承 (Loop Dynamic Bearing, LDB)
  • 風扇平均故障間隔 >200,000 小時
  • 風扇連接介面 4-Pin (PWM)
  • 風扇額定電壓 12 VDC
  • 風扇額定電流 0.12A
  • 風扇安全電流 0.35A
  • RAM Clearance N/A
  • 產品保固 5年
  • 產品類型 CPU水冷散熱器
  • 產品類型 Workstation Cooler
  • 水冷排尺寸 240
