NR200P MAX 機殼 image number 0
NR200P MAX 機殼 image number 1
NR200P MAX 機殼 image number 2
NR200P MAX 機殼 image number 3
NR200P MAX 機殼 image number 4
NR200P MAX 機殼 image number 5
NR200P MAX 機殼 image number 6
NR200P MAX 機殼
NR200P MAX 機殼
NR200P MAX 機殼
NR200P MAX 機殼
NR200P MAX 機殼
NR200P MAX 機殼
NR200P MAX 機殼
強效SFF電腦,裝機易如反掌
NR200P MAX 機殼
Cooler Master推出MAX系列,以純熟的技藝打造,集結散熱、電源、機構等多領域三十年的專業經驗。
立即購買
SFF Building Just Got Easier
The First of Cooler Master’s MAX Series; Cooler Master’s Expertise at Its Finest; SFF Building Refined Luxurious Out-of-the-Box Solution.
Customization
STREAMLINE YOUR BUILD EXPERIENCE
The pre-installed, pre-routed power supply and CPU-cooler
allows for ease of building and optimal cable & tubing management.
Install a motherboard, HDDs and finish off with a GPU:
No hassle, no routing. Stow away excess cables and you’re good to go.
Performance
Designed For High-End ITX Systems
Our Achievements
AWARDS
GPU panel
PATENTED QUICK INSTALL GPU PANEL
This exclusive, removable GPU panel design simplifies the process
of mounting large GPUs in SFF chassis, enabling greater hardware
support and hands-free installation.
Motherboard
EASILY ACCESSIBLE M.2 DRIVES
The motherboard tray is designed for unrestricted access to any m.2 drives installed behind the motherboard. The ventilated paneling ensures that m.2 storage drives installed in this location runs cool and reliably.
PREMIUM PCIE GEN4 RISER CABLE INCLUDED
NR200P MAX comes equipped with a premium shielded PCIe Gen4 Riser Cable to ensure both maximum compatibility and performance with all graphics cards.
Cooling Efficiency Beyond Compare
NR200P MAX’s built-in 280mm radiator boasts unmatched cooling efficiency owing to a 25% increase in aluminum fin surface area.
Compatible with a wide variety of Intel and AMD sockets (all brackets included), the AIO’s upgraded Gen3 dual-chamber pump is bound to keep any CPU running at optimum performance. Included Sickleflow 140 Non-LED fans utilize a two-tier sealing mechanism to prevent dust accumulation, resulting in longer serviceable life span and silent performance.
PSU Features
Performance Unbounded
The pre-installed, 80 Plus Gold efficiency PSU features 16AWG PCIe full-modular, high efficiency cables tailor-made to allow ease of installation without the hassle of cable management. Tailor-made to a small form factor, this PSU allows clearance for the largest, widest graphics cards while making the most of NR200P MAX’s 18 liter chassis.
Join The Discussion!
Got any feedback or future product requests? Or maybe you just want to chat with our product team. Join us our community on Discord and Reddit to talk directly to the designers of the products, or participate in feedback surveys, giveaways and more! We want to hear from you!
  • 產品型號 NR200P-MCNN85-SL0
  • 外觀顏色 黑 / 灰
  • 材質 - 外觀 SGCC 鋼材
  • 材質 - 左側板 強化玻璃 x1
  • 尺寸 (長X寬X高) 377 x 185 x 292mm (包含突出物)
  • 容量 18.30L
  • 相容主機板 Mini-ITX
  • 擴充槽 3
  • 硬碟架 - 5.25" 光碟機 0
  • 硬碟架 - 3.5" / 2.5" 複合式 1
  • 硬碟架 - 2.5" SSD 2 (最大. 3)
  • I/O 面板 2x USB 3.2 Gen 1 (USB 3.0)
  • 內附配件 1x MasterAccessory Riser Cable PCIe 4.0 x16 - 35mm
  • 內附水冷散熱 280mm 水冷散熱器
  • 內附電源供應器 V850 SFX Gold
  • 風扇支援 - 上方 2 x 120mm / 2 x 140mm
  • 風扇支援 - 下方 1 x 120mm (max 15mm, with 3.5" HDD at the bottom)
  • 水冷支援 - 上方 240mm / 280mm
  • 預裝空間 - CPU 散熱器 67mm
  • 預裝空間 - 電源供應器 130mm
  • 預裝空間 - 顯示卡 L: 336mm (包含電源接頭)
  • 防塵濾網 底部
  • 支援電源供應器 SFX
  • 保固 2年 (機殼)
  • 保固 2年 (散熱器)
  • 支援電源供應器 SFX-L
  • 防塵濾網 左側
  • 預裝空間 - 顯示卡 H: 160mm (包含電源接頭)
  • 風扇支援 - 下方 2 x 120mm (max 15mm, w/o 3.5" HDD at the bottom)
  • 內附水冷散熱 2 x 140mm SickleFlow PWM
  • I/O 面板 1x 3.5mm 耳機孔 (音源+麥克風)
  • 硬碟架 - 3.5" 硬碟 1 (最大. 2)
  • 相容主機板 最大支援尺寸: 170 x 180mm
  • 尺寸 (長X寬X高) 361 x 185 x 274mm (不含突出物)
  • 材質 - 左側板 穿孔鋼板 x1
  • 材質 - 外觀 網孔
  • 材質 - 外觀 ABS
  • 內附水冷散熱 Gen 3 Cooler Master Pump / CPU Block
  • 預裝空間 - 顯示卡 W: 75mm (triple slot)
  • 防塵濾網 右側
  • 保固 10年 (電源供應器)
  • 尺寸 迷你 ITX
  • 防塵濾網 頂部
