NR200P MAX 機殼 image number 0
NR200P MAX 機殼 image number 1
NR200P MAX 機殼 image number 2
NR200P MAX 機殼 image number 3
NR200P MAX 機殼
NR200P MAX 機殼
NR200P MAX 機殼
NR200P MAX 機殼
強效SFF電腦,裝機易如反掌
NR200P MAX 機殼
Cooler Master推出MAX系列,以純熟的技藝打造,集結散熱、電源、機構等多領域三十年的專業經驗。
Capability
ENHANCE SUPPORT FOR HIGH-END ITX SYSTEMS
The NR200P MAX V2 enhances GPU support capability up to 356.7mm and includes a GPU holder and a 12VHPWR power cable for the latest GPUs. Combined with tailor-made thermal and power delivery solutions, the NR200P MAX V2 comprehensively satisfies users' demands for a high-end ITX system with a 'ready-to-go' package
PATENTED QUICK INSTALL GPU PANEL
NCORE-PATTERNED' STEEL LEFT SIDE PANEL AND TEMPERED GLASS VENTILATED OPTIONS
The NR200P MAX V2 is equipped with an 'Ncore-patterned' side steel panel. This upgrade assists the system in increasing ventilation, ensuring that power-hungry builds stay cool and run more efficiently. Additionally, the edge-to-edge tempered glass panel provides a premium aesthetic.
TAILOR-MADE PREMIUM COOLING AND ATX 3.0 SUPPORTED POWER DELIVERY
Next-gen systems are becoming more and more power-hungry and to power it all, NR200P MAX V2 implements an ATX 3.0 850W Gold-certified PSU with custom-length textured cables specifically designed to cover all performance needs.
A 280mm radiator, two pre-installed SickleFlow PWM 140mm fans and Cooler Master's highly acclaimed 3rd generation pump/CPU block provide reliable cooling for the CPU. AMD sockets up to AM4 and AM5 and Intel sockets up to LGA1700 are fully supported.
TRIPLE-SLOT GPU SUPPORT
The NR200P MAX V2 supports triple-slot GPUs up to 357.6mm in length and 160mm in height. Additionally, this chassis has been specifically designed for vertically mounted GPUs to ensure powerful performance.
PREMIUM PCIE GEN4 RISER CABLE INCLUDED
NR200P MAX V2 comes equipped with a premium shielded PCIe Gen4 Riser Cable to ensure both maximum compatibility and performance with all graphics cards.
EASILY ACCESSIBLE M.2 DRIVES
360° ACCESSIBILITY
PERFORMANCE UNBOUNDED
The pre-installed, 80 Plus ATX 3.0 Gold efficiency PSU features 16AWG PCIe full-modular, high efficiency cables tailor-made to allow ease of installation without the hassle of cable management. Tailor-made to a small form factor, this PSU allows clearance for the largest, widest graphics cards while making the most of NR200P MAX V2’s 18 liter chassis.
COOLING EFFICIENCY BEYOND COMPARE
NR200P MAX V2’s built-in 280mm radiator boasts unmatched cooling efficiency owing to a 25% increase in aluminum fin surface area.
Compatible with a wide variety of Intel and AMD sockets (all brackets included), the AIO’s upgraded Gen3 dual-chamber pump is bound to keep any CPU running at optimum performance. Included Sickleflow 140 Non-LED fans utilize a two-tier sealing mechanism to prevent dust accumulation, resulting in longer serviceable life span and silent performance.
ATX 3.0 COMPATIBLE
ATX 3.0 COMPATIBLE
Cooler Master's V Gold power solutions, renowned for their extraordinary performance delivery and high reliability, have been upgraded to support ATX 3.0. This ensures that the system is capable of satisfying all levels of performance needs.
  • 產品型號 NR200PV2-MCNN85-SL0, NR200PV2-MCNN85-SL1
  • 外觀顏色 Grey
  • 材質 - 外觀 SGCC Steel, Mesh, ABS Plastic
  • 材質 - 左側板 Tempered Glass x1, Steel x1
  • 尺寸 (長X寬X高) 377 x 185 x 292mm (incl. Protrusions), 360 x 185 x 274mm (excl. Protrusions)
  • 容量 18.25L
  • 相容主機板 Mini-ITX, Max. size: 170 x 180mm
  • 擴充槽 3
  • 硬碟架 - 5.25" 光碟機 0
  • 硬碟架 - 3.5" 硬碟 1 (Max. 2, remove bottom fan)
  • 硬碟架 - 3.5" / 2.5" 複合式 1
  • 硬碟架 - 2.5" SSD 1 (Max. 2)
  • I/O 面板 - USB 連接埠 2x USB 3.2 Gen 1 (USB 3.0), 1x USB 3.2 Gen2x2 Type C
  • I/O 面板 - 音源輸入 / 輸出 1x 3.5mm Headset Jack (Audio + Mic)
  • 內附配件 1x PCIe 4.0 x16 Riser Cable, 1x GPU Holder
  • 內附水冷散熱 2x 140mm SickleFlow PWM, 280mm Radiator, Gen 3 Cooler Master Pump / CPU Block
  • 內附電源供應器 V SFX Gold 850W ATX 3.0
  • 風扇支援 - 上方 2 x 120mm / 2 x 140mm
  • 風扇支援 - 下方 2 x 120mm (1x max 15mm, w/o 3.5" HDD at the bottom)
  • 水冷支援 - 上方 120 / 140 / 240 / 280mm
  • 預裝空間 - CPU 散熱器 67mm
  • 預裝空間 - 電源供應器 130mm
  • 預裝空間 - 顯示卡 Exceed front bracket: L: 357.6mm (incl. power connector), H: 160mm (incl. power connector), W: 73mm (triple slot)
  • 預裝空間 - 顯示卡 Not exceed front bracket: L: 334mm (incl. power connector), H: 160mm (incl. power connector), W: 80mm (triple slot)
  • 防塵濾網 Bottom, Left, Right, Top Panels
  • 支援電源供應器 SFX, SFX-L
  • 保固 2 年 (機殼)、2 年 (散熱解決方案)、10 年 (電源供應器)
  • 尺寸 迷你 ITX
