MWE Gold 850 V2 ATX 3.0 Ready White Edition image number 0
MWE Gold 850 V2 ATX 3.0 Ready White Edition image number 1
MWE Gold 850 V2 ATX 3.0 Ready White Edition image number 2
MWE Gold 850 V2 ATX 3.0 Ready White Edition image number 3
MWE Gold 850 V2 ATX 3.0 Ready White Edition image number 4
MWE Gold 850 V2 ATX 3.0 Ready White Edition image number 5
MWE Gold 850 V2 ATX 3.0 Ready White Edition image number 6
MWE Gold 850 V2 ATX 3.0 Ready White Edition image number 7
MWE Gold 850 V2 ATX 3.0 Ready White Edition image number 8
MWE Gold 850 V2 ATX 3.0 Ready White Edition image number 9
LEVEL UP YOUR POWER
Introducing the MWE Gold V2 ATX 3.0 Ready, the evolutionary next step in Cooler Master power.
High Temperature Resilience​
A 50°C operating temperature and high quality Japanese capacitors allow for pushing your machine to the limits.​
Certified Efficiency
The MWE Gold V2 ATX 3.0 Ready is certified to achieve more than 90% efficiency at typical loads.​​
Fully Modular Cabling
Three 8-pin Connectors
Up to 600W of power is split between three 8-pin connectors, providing enhanced safety.
  • 型號 MPE-8501-AFAAG-3G
  • ATX 版本 ATX 12V Ver. 3.0
  • 功率因數校正 主動式 PFC
  • 輸入電壓 100-240V
  • 輸入電流 12-6A
  • 輸入頻率 50-60Hz
  • 尺寸 (長 x 寬 x 高) 160 x 150 x 86 mm
  • 風扇尺寸 120mm
  • 風扇軸承 HDB
  • 轉換效率 典型轉換 ≥90%
  • 80 PLUS 評級 80 PLUS 金牌
  • ErP 2014 Lot 3 符合
  • 工作溫度 0-50°C
  • 電源良好信號 100 - 150 ms
  • 持續輸出時間 ≥ 16ms
  • 平均故障間隔 (MTBF) >100,000 小時
  • 保護機制 UVP / OVP / OPP / OTP / SCP / OCP
  • 安規 TUV, CE, CCC, EAC, RCM, cTUVus, FCC, BSMI, BIS, UKCA
  • ATX 24 Pin 電源接頭 1
  • EPS 4+4 Pin 電源接頭 1
  • EPS 8 Pin 電源接頭 1
  • SATA 電源接頭 12
  • 周邊 4 Pin 電源接頭 4
  • PCI-e 6+2 Pin 電源接頭 4
  • 12VHPWR 電源接頭 1 (1 對 3)
  • 分類 750瓦以上
  • 產品系列 MWE Gold 系列
  • 模組化 全模組化
  • 80 Plus 金牌認證
  • Watts 850W
